my 4runners on tilt!
Old Mar 20, 2009 | 07:21 PM
kickrocks's Avatar
my question concerns my 92 4runner i bought it a couple months ago and i dont know if its lifted or not but when iam standing behind the vehicle or in front of it the rig leans hard to the driver side! its drivin me nuts cuz i dont even know where to begin to try to fix this problem. if anybody can help by tellin me if they know why it is like that and how i can fix it it would be much appreciated! thanks in advanced
Old Mar 20, 2009 | 07:33 PM
4banginRunner's Avatar
Slop of the area you parked? Blown/Missing shock? Sagged coils?
Pics would really help
Old Mar 20, 2009 | 07:42 PM
Junkers88's Avatar
Measure from the top of the rim to the bottom of the fender on all four fenders. Let us know what the measurements are for each one. This might make it easier for us to figure out what may be causing the tilt.
Old Mar 20, 2009 | 10:37 PM
abecedarian's Avatar
yup... measure the 4 corners like junker said...
then we can figure out if the driver's front is low (weak / bad torsion bar on that side), or the passenger front is high (weak / bad coil on the driver's rear) or the frame is bent...
Old Mar 24, 2009 | 03:21 PM
kickrocks's Avatar
thanks fellas for responding sorry i havent been able toreport back faster! Anyway the measurments on the driver side are 14 inches and on the passenger side its at 15 1/2 inches. how bad is it? thanks again
Old Mar 24, 2009 | 03:25 PM
Squeebs's Avatar
check the shocks, springs. and t-bars
Old Mar 24, 2009 | 03:36 PM
toyota4x4907's Avatar
shocks have nothing to do with ride height, unless otherwise noted.
but yeah check the t-bars and make sure all the a-arms are straight and everything is okay in the front.
was the previous owner heavy set, maybe?
Old Mar 24, 2009 | 03:40 PM
kickrocks's Avatar
check for what exactly? everything i seen looks normal. it did look like underneath the coil spring on the pass.side it had a plate/spacer and the driver side did not have that.that was all i saw but the whole side is off a inch and half from the pass.side
Old Mar 24, 2009 | 03:45 PM
oh. the WHOLE driver's side is leaning? And you say there seems to be a spacer on the passenger's side?..I bet thats what it is. I bet the previous owner put in a spacer to counteract the rear sagging and the passenger's side droop due to the fuel tank. Either take the spacer out or put one in on the driver's side that complements the other.
Old Mar 24, 2009 | 03:50 PM
kickrocks's Avatar
yeah but that will only fix the back of the driver side what about the front of the 4runner? or is there a place for a spacer up front too?
Old Mar 24, 2009 | 03:59 PM
try fixing the rear first. I bet the front will more or less level out once you fix the rear.
Old Mar 24, 2009 | 04:15 PM
Jay351's Avatar
Just adjust the torsion bar. If you need to adjust it alot it will throw your alignment out.
Old Mar 24, 2009 | 04:16 PM
arizonaguy's Avatar
wierd problem
Hmmm
Old Mar 26, 2009 | 02:35 PM
89whitetoyota's Avatar
From: Cincinnati, Ohio - Amelia is the exact place. There is no one else on this site from where I am. Seems like everyone is from Cali or Washington. I guess I need to move.
Wouldnt you have to be morbidly obese to cause a whole side of a runner to have a Detroit Lean like that? Ba da ba ba ba.......IM LUGGIN IT!!!!
Old Mar 26, 2009 | 07:36 PM
LOL. Read that thread about the weirdest things that happened while working on a vehicle.
Flying91
45
Apr 11, 2024 04:39 PM
icentropy
Sep 16, 2020 02:47 PM
BeMiceElf
Oct 10, 2015 09:40 PM
Poppie51
Jul 23, 2015 05:03 PM
Poppie51
Jul 16, 2015 06:16 PM
