Help Lost All Power
Old Jun 9, 2008 | 09:49 PM
olharleyman's Avatar
Help Lost All Power
I had a battery wire ground out have have lost all power but headlights and doorbuzzer door lights 1990 4runner please help
Old Jun 9, 2008 | 10:31 PM
thook's Avatar
Oops...hate that for you.
I'll bet you've just blown a fuse or two. Check the main EFI fuse first.
Old Jun 9, 2008 | 11:02 PM
Wheres that at??? but not even my windows will roll up dash lights stereo no start action nothing help
Old Jun 9, 2008 | 11:18 PM
thook's Avatar
I assume you know where the fuse box is on the pass side wheel well, right? Well, with an ohm meter you can start testing to see what fuses in there have continuity and which ones don't. On my meter, there's a function for testing with a beeper. It will beep if this fuse is still good. Otherwise, it will show zero on the meter. If it's bad, it will not change and show a one or infinite....no continuity. The EFI fuse should be a 15 amp fuse. The headlight fuses and all are in there, but I do believe stereo fuses and the like are behind the kickpanel on the driver's side of the cab interior. Test the fuses under there the same way.
I suppose you really oughtta test the main fusible link first, though.
http://personal.utulsa.edu/~nathan-b...95efimainr.pdf
You'll see it when you look in there. It's the first 30amp fuse in the line of fuses.
Old Jun 9, 2008 | 11:46 PM
I found it its the 80 amp fuse to everything
Old Jun 9, 2008 | 11:51 PM
thook's Avatar
80 amp? No schniztle?! Wonder why the FSM doesn't point that one out?
Where is that one located?
Old Jun 10, 2008 | 01:11 AM
notanymore's Avatar
its the fuseable link, its in the fusebox under the hood. it wasnt in that page of the fsm because its not specificaly just the efi, but more of a master fuse for the whole truck.
Old Jun 10, 2008 | 07:33 AM
Crawdad's Avatar
Yes. The fuse is about $3 at Autozone, and to replace it, you have to:
1) (After disconnecting the battery) take off the 2 bolts holding the under-hood fuse block down. The fuse block is on the passenger side fender in the engine bay.
2) take off the bottom cover on the fuse block, via 2 clips on one side.
3) Press on the clip where the fuse hooks in, and push the fuse down. It will come out the bottom.
4) Undo the 3 screws, remove the wires. I recommend using a nut driver or socket to take the screws off, they strip extremely easily. There is one large screw, a 10mm, and two smaller ones, 8mm or 6mm, I don't remember.
5) Hook the new fuse up, and screw the wires back onto it, and push it back up into the fuse block. Installation is the reverse of removal .
If it blows again, you have some problems somewhere. Probably an underhood main wire shorting to ground.
I recommend taking the old fuse out and matching it up at the parts store. There are several different ones. You want the one that looks like this:
Old Jun 10, 2008 | 07:45 AM
904_runner's Avatar
Good luck, i hope it was only a one time thing!
Old Jun 10, 2008 | 05:00 PM
just a 22re's Avatar
next time try not welding your wedding ring to the battery ok buddy it hurts alot!
Old Jun 10, 2008 | 05:58 PM
SOCKET #9 IN THE BOX CLOSEST TO THE FIREWALL BY ITSELF
7 BUCKS AT STEALERSHIP
yEA NOW MY FINGER IS AN ODD BLACK AND RING HAS A NEW LITTLE NUB ON IT LOL
Old Jun 10, 2008 | 06:13 PM
thook's Avatar
I'm wondering just how you would know that, Allan....
Old Jun 10, 2008 | 07:08 PM
toyotanick's Avatar
hahaha when i first saw the title, "help, lost all power" i thought you had installed a 3vze! haha
Old Jun 10, 2008 | 07:13 PM
thook's Avatar
Old Jun 12, 2008 | 02:28 PM
Crawdad's Avatar
Damn, I was quoted $14 at the local dealership. But they're a bunch of idiots.
Old Jun 12, 2008 | 02:42 PM
Now that's funny I don't care who you are!!!!!!!!!!!!
Old Jun 12, 2008 | 04:03 PM
76ANTHONY's Avatar
dohhhhhhhhh
Old Jun 12, 2008 | 04:25 PM
abecedarian's Avatar
I was expecting to read-
"I just got married"
Old Jun 12, 2008 | 06:01 PM
thook's Avatar
Now we know what happened to Kirk.....
JNapolitano
Nov 14, 2019 07:46 PM
coleypull15
Nov 3, 2015 07:41 AM
o2raybid
Sep 4, 2015 12:45 PM
Sidherish
Aug 2, 2015 01:42 PM
Jeffreynmandy
Jul 18, 2015 08:26 AM
