HELP! 22RE hesitating/back firing
Old Nov 7, 2009 | 01:15 PM
Yotapowa's Avatar
My 86 22RE truck doesnt like accelerating. This only happens once the truck is brought up to operating temperature, if I am a little enthusiastic with thego pedal, it starts hesitating, then bogs down from 2500RPM to about 1000 then backfires. If i drive without giving it too much gas and shift by 2500 RPM it does not cause a problem. Has new plugs/wires/cap/rotor
Thanks
Old Nov 7, 2009 | 01:52 PM
milehigheric's Avatar
Whats your timing at?...check to make sure your dizzy is advancing properly.
Old Nov 7, 2009 | 01:59 PM
My99's Avatar
Did it do this before you changed the plugs & distributor? As Eric mentioned, sounds like a timing problem...
Old Nov 7, 2009 | 09:51 PM
Yotapowa's Avatar
No it did not do this before I changed the plugs, however It did not start doing it immediately after either
Old Nov 8, 2009 | 01:48 AM
Have you pulled the plugs to see what they look like? What plugs and leads are they?
Old Nov 8, 2009 | 07:23 AM
abecedarian's Avatar
Sounds to me like a vacuum leak or problem with the intake duct.
Old Nov 8, 2009 | 07:44 AM
03vrod's Avatar
Timing and vacuum both are great places to start.How's your idle alot of times the computer will raise the idle to keep the engine running if there's a vacuum leak.
Old Nov 8, 2009 | 07:03 PM
22re's ECU's don't have the capability to adjust idle speeds.
Old Nov 8, 2009 | 07:33 PM
awm3tm's Avatar
I would check plugs and timing first. My 87' 4runner 22re has an issue, I started it last week ran for a minute then quit. Not getting fuel, checked relay (good) so replace fuel pump. still no power to it??????? What would cause this? When I started it last week it was being jumped!
Thanks
Old Nov 9, 2009 | 03:34 AM
03vrod's Avatar
Sorry I forgot.No IAC on the 22RE you have to manually adj the screw on the intake.Thanks abecedarian.
Doug4320
Mar 24, 2018 10:11 PM
256mbaker
Jul 31, 2015 06:45 PM
Sandman
Jul 14, 2015 12:36 PM
ZONAYODA
Jul 13, 2015 07:17 PM
