great... ANOTHER TPS...fml
hey whats guys...now before i start with my stupid issue, id like to make it clear that i indeed did search prior to making this thread and im looking for verification and clarity more so then a "how-to"... so anyway without further ado. i have a 1993 toyota pick-up with the 22 RE engine. i have frankenyota's tps adjustment walk through as well but it seems i cant get my base line to start adjusting. my engine/TB seems to be a late model design just based on the horizontal positioning ive seen in the 22RE variations. the pictures well further elaborate.
in the first photo my tps is NOT on the throttle body (red circle) and the throttle is obviously closed indicated by the blue circle
in the second photo this where my tps sits at idle but the holes to secure it it aren't lining up. i should also mention that the throttle plate is in contact with the stop screw
now in the third picture the tps is mounted in its lowest position to line up with the holes. As a result the throttle flap opens a considerable amount. ive tried adjusting from this point but to no avail. the engine constantly surges into the what sounds like 3k rpms if i were to put everything back together and start. the tps is good and is an OEM part from toyota PN #98500-0330
now guys my question to you is am i supposed to follow the procedure to adjust the tps while it is in this known position? ive tried to adjust the stop screw a few times and mounting the tps in numerous positions but i always end back in the same positioning for the idle. any help would be appreciated in clarifying where i should start.. its such a stupid issue i hate asking but ill be the idiot for the day as long as i can get my truck back on the road. thanks guys
Why did you remove it? I completely cleaned my Throttle Body and new gasket on my 91 4X4, I left it alone.
Had to look it up to find out what you were talking about, avoid the acronyms, it's a throttle position sensor, TPS wasn't in the index
Ok sorry about that. I removed it because it had an idle of about 300 rpms and a misfire. I performed 2 complete tuneups. After running on the highway for an extended period of time, the truck would stall out at intersections. So when I went to adjust the throttle position sensor by loosening the 2 screws... the sensor fell off the throttle body. I'm assuming it was never properly on the throttle body ears in the first place..
yes, it will be a little off. Just slide it in and line up the holes. It will be a little under tension from a spring. You may have noticed the plastic rod inside the TPS twisted a bit when you removed it. Mine works fine. However, if your TPS is a 4 prong style, you will have to do an OHM test to get it set right. The FSM covers it, but in case you don't have it, here is how you set it.
Have you made sure your throttle butterfly valve is fully closed? I.e. have you adjusted the throttle stop screw to make sure it is? You want it closed completely just not so far closed that it gets stuck. Very tight tolerance.
Just wondering because it seems to me that if the butterfly were adjusted too far open, it would tweak the TPS as it is in your pic #2. But as others have mentioned, there should be a little bit of tension on it when the screw holes line up.
Have fun adjusting that crap. It's a tricky one! I'm about to do mine today
in this picture the throttle position sensor is on the throttle ears and the throttle butterfly is closed but i cant adjust because i cant secure it. this leads me to believe my current throttle sensor is incorrect but it just simply is able to allow the adjustment i would need. now if i were to "advance" this sensor in a CCW position the throttle flap is damn completely open!?! i know this cant be right. again if anyone has correct part numbers or rather all the available part numbers including supersession ones that would be great
Hmm yeah sounds funky to me.
Perhaps the paddles connected to the butterfly valve shaft are wrong for your TPS. They can be 90deg shifted depending on the model year. Check it out:
It is indeed possible that your TPS needs the other paddle to properly align itself. That pic I took during my early to late model intake swap. The link to that mod is in my signature where there is a bit more description.
Maybe if you took a pic of the paddles (with TPS off and butterfly valve closed/at rest) it would help pinpoint that for you. Sounds to me like you need the different paddle.
If for some reason you have to adjust your throttle stop screw (doubtful unless you messed with it like I did), when complete I suggest you use some lock tight once set to hold it in place. You can use an ohm meter and ohm it to the closed position to find the sweet spot. You will need the FSM to figure this out or more search to find the info. Or, you can use your tack, after it is warm and set it to the correct RPM. Think small corrections at the screw as it really is a fine tune procedure.
Are you sure you're aligning the pins correctly?
I've only installed one and it's on my 91 22re. I ordered one that had the same part number as the one I took off (same part # you have in the pic). When I first placed it on the throttle body the mounting position was off like yours.
I had it on a bench and eventually realized I was aligning the pins in the wrong position because they were on the wrong side of the notches in the TPS. They have to be seated into those two little notches/cutouts on the back of the TPS with a little spring tension to function correctly. I can't 100% remember what I had to do to get the pressure. I may have had to open the throttle a little to get the pins on the other side of the cutouts in the TPS.
Everything checked out normal with the multimeter and it's been fine since then.
Messing around with the TPS made me wish I had a good old analog style multimeter with the sweeping needle.
OP, you're only about 30* off from level, not 90*, and I highly doubt someone swapped ears into your TPS anyway. That part is for the 22re engine. The 3vze TPS came 180* apart year-dependent but the procedure for adjusting them is the same, hence that different pic above. (Jenny do you have the 4 or 6 cyl?) I would agree with the guy above me that you probably have the ears slightly out of position. The TPS is incredibly sensitive to set, a hair either way can throw it out of adjustment, you'll need an ohmmeter.
Did you check fuel, air, spark and compression for your misfire? If it's only when warmed up the O2 is my first place to look, pick up one of those analog VMs and check for needle pulse.
Here's the correct manual section: http://personal.utulsa.edu/~nathan-b...34throttle.pdf
shadowbirdie: Note where it says: "NOTICE: To prevent deterioration, do not clean the throttle position sensor." I'm sure you were very careful.
Granted, I am one who took their TPS completely apart
We'll give this a try thanks Jenny...
So far I just left it alone during the TB removal and clean up, seemed easiest
"if it works, don't fix it" but seems simple enough. As a former IPC3 microsolderer
this would be big parts to work on, but I don't have a microscope anymore, still have my PS1 Metcal though.
And getting a tiny quantity of dielectric is tough,
have to buy a lifetime supply just for a smidgen needed..
True that, I use the analog one I have more than the digital one. O2 sensors, fuel injector pulses, and anything else you could do with a digital. Reminds me I need to order a new potentiometer for it though.
and here we are...
a1jasong
Aug 6, 2013 11:17 AM
SnoViking
11
Nov 3, 2005 04:27 PM
