fuel smell wont go away
Old 10-04-2007, 11:40 AM
littleredtoy's Avatar
ive got a 1988 4runner with a really bad fuel smell. Ive put all new o-rings, boots, and compression rings on the fuel line and the injectors, but it still has the fuel smell. I need some help people!
Old 10-04-2007, 11:43 AM
oh ya its a 3vze, v6
Old 10-04-2007, 11:45 AM
n4ynu1010's Avatar
Fuel Smell
From in the cab ? Under the Hood ? From the Exhaust ?
Old 10-04-2007, 11:56 AM
n4ynu1010's Avatar
If I had to take a shot in the dark not knowing yours is like my '90 and I take for granted that you have made sure you do not have a fuel leak anywhere like in any of the hard line to the engine then all that being true I would have to say take a hard look at the Gas Vapor Recovery lines coming back to engine compartment from the gas tank/filler neck and see if you have a broken/deteriorated/dis-connected hose that could be or would be releasing gas vapor from your tank , mine has a charcoal filter at the fiewall and if the hose to this were to go bad (from the tank) then I am sure I would smell gas vapor .
Hope this helps a little otherwise I will check back and see where you are smelling it and see if I can offer any other ideas .
Guy
Old 10-04-2007, 11:59 AM
Gator's Avatar
strike a match!.....Just kidding
Sorry, I just got paid, and tomorrows Friday so I'm in a particularly good mood. Somebody was going to say it sooner or later and I figured it may as well be me.
Old 10-04-2007, 12:16 PM
Kiff's Avatar
I have the same issue. Smell of stale gas in the cab, I'm figuring it's something to do with the charcoal canister.
Old 10-04-2007, 12:29 PM
n4ynu1010's Avatar
Here's a pic that gives a explanation of the cannister like I have :
http://www.4crawler.com/4x4/CheapTri...ne_Pix/19.html
From what I have read the line leaving the bottom should be tucked in hole in the frame , trying to get you guys the test proceedure for it , I remember seeing it somewhere
Old 10-04-2007, 12:40 PM
n4ynu1010's Avatar
Ok guys , here is the service/maint proceedure from the FSM , Have fun
Charcaol Cannister Service/Check for 22RE motor
http://personal.utulsa.edu/~nathan-b...17evaporat.pdf
Charcoal Cannister Service/Check for 3VZE 3.0
http://personal.utulsa.edu/~nathan-b...76evaporat.pdf
Old 10-04-2007, 12:56 PM
ok, i just found out that the line that comes from the bottom of the charcoal canister was full of dirt, could that have caused a problem?
Old 10-04-2007, 01:32 PM
n4ynu1010's Avatar
I would imagine that it would since that is used for the vent on the canister , check and see if you have a hole in your frame rail near that hose( the end of it that is ) as from what I have read that hose should be tucked in the frame rail to prevent that problem .
sandyota
02-04-2021 11:16 AM
Sleaker
08-26-2020 06:03 AM
Eggslinger
06-08-2019 03:32 PM
raptor510
08-19-2015 02:15 PM
tomczaksdiesel
07-26-2015 10:35 PM
Quick Reply: fuel smell wont go away
