Front Vent Window Replacement?????
Old Oct 13, 2010 | 08:18 PM
Laofrog's Avatar
Has anyone ever replaced the front vent windows on a 93 truck to a full window without the vent? If so what changes do you need to make if any?
Old Oct 14, 2010 | 10:10 AM
iamsuperbleeder's Avatar
best bet would be to swap out the entire door for one with the window style you want
any Pickup from 89 to 95 will have the same body style, and you can swap doors with them. 4-door 4Runner doors will not work; the doors are a different size. 2-door 4Runner doors WILL work, but don't count on that as a source; they're far and few between, and chances are you wont locate one in a scrap yard
Welcome to YotaTech!
Old Oct 15, 2010 | 11:53 AM
Laofrog's Avatar
Is there any way of doing this without swapping out the whole door? Can I replace the trim around the window? Will the motor for the window I have work with a new window?
Old Oct 15, 2010 | 12:20 PM
Outsane's Avatar
not sure if it helps but I have done it on my 84
Old Oct 15, 2010 | 12:58 PM
Laofrog's Avatar
Cool! What did you have to do?
Old Oct 15, 2010 | 02:37 PM
JamesD's Avatar
Yes you can do it. You need to change the guts and do not forget about the seals.
voiddweller
19
May 2, 2016 09:10 PM
Jmiller1023
23
Aug 6, 2015 07:03 PM
bigblue82
10
Jul 6, 2015 08:27 AM
Vargntucson
Jul 4, 2015 12:15 PM
