Flywheel/pressure plate bolts
Old Jan 27, 2009 | 08:35 AM
91Toyota's Avatar
Still can't find these bolts. I can find a set of HD pressure plate bolts on marlin crawler but can't find flywheel bolts.
So, what size are they? I'm going to just go to a hardware store and get them. I "could" get the bolts out of the torque converter, but they are the wrong size. How long are they???
Thanks
Old Jan 27, 2009 | 08:56 AM
JonnyBoy's Avatar
90913‑01011 is the Toy part number.
The size is listed as 11-1.25PX26-18
Old Jan 27, 2009 | 10:55 AM
91Toyota's Avatar
And what does 11-1.25PX26-18 mean?
Old Jan 27, 2009 | 12:10 PM
JonnyBoy's Avatar
11mm, 1.25 thread pitch, 18mm long...dunno about the 26 part exactly.
Old Jan 27, 2009 | 12:25 PM
91Toyota's Avatar
okay, that helps A LOT! Thank you!
Old Jan 27, 2009 | 12:33 PM
JonnyBoy's Avatar
might be 26 mm long? now that I think about it, not sure. Sorry, but my parts diagram doesn't really show the bolt well.
Old Jan 27, 2009 | 12:59 PM
desconhecido's Avatar
my guess is that it's 26mm long with 18mm threaded.
11mm -- is that a common metric bolt?
1st Toyota lists the part number at 2.63 each. Might be best to get them from Toyota.
Old Jan 28, 2009 | 10:06 AM
Georgiadave's Avatar
11MMx1.25 bolts are a standard thread, but generally not used. Why Toyota used them at all is a mystery, but it was bad design. I could not find them at fastener supply houses, and my Toyota dealer could not find them at another dealer in the state.
I did not try Marlin, but they may have the bolts since they sell flywheels.
Good luck with it.
Old Jan 28, 2009 | 11:17 AM
91Toyota's Avatar
I just got some from a local hardware store (specializes in bolts!) and they had them. I also got some pressure plate bolts too. Cost me $5.14
Old Mar 14, 2009 | 05:48 AM
jaxrunner's Avatar
I forgot to use lock-tight and 4 bolts backed out and 2 others sheared. Finding these bolts is not easy. Lesson learned!!
smithyboy69
Nov 28, 2015 04:13 PM
garagespace
Oct 11, 2015 10:59 AM
RobotMoose
Sep 2, 2015 05:53 AM
TransAmBandit
Jul 28, 2015 11:30 PM
Snort
Jul 9, 2015 03:58 PM
