Flywheel/pressure plate bolts
Still can't find these bolts. I can find a set of HD pressure plate bolts on marlin crawler but can't find flywheel bolts.
So, what size are they? I'm going to just go to a hardware store and get them. I "could" get the bolts out of the torque converter, but they are the wrong size. How long are they??? Thanks |
90913‑01011 is the Toy part number.
The size is listed as 11-1.25PX26-18 |
And what does 11-1.25PX26-18 mean?
11mm, 1.25 thread pitch, 18mm long...dunno about the 26 part exactly.
okay, that helps A LOT! Thank you!
might be 26 mm long? now that I think about it, not sure. Sorry, but my parts diagram doesn't really show the bolt well.
my guess is that it's 26mm long with 18mm threaded.
11mm -- is that a common metric bolt? 1st Toyota lists the part number at 2.63 each. Might be best to get them from Toyota. |
11MMx1.25 bolts are a standard thread, but generally not used. Why Toyota used them at all is a mystery, but it was bad design. I could not find them at fastener supply houses, and my Toyota dealer could not find them at another dealer in the state.
I did not try Marlin, but they may have the bolts since they sell flywheels. Good luck with it. |
I just got some from a local hardware store (specializes in bolts!) and they had them. I also got some pressure plate bolts too. Cost me $5.14:D
I forgot to use lock-tight and 4 bolts backed out and 2 others sheared. Finding these bolts is not easy. Lesson learned!!
