engine problems!
Old May 21, 2007 | 07:03 PM
andtheman1988's Avatar
engine problems!
I gotta a 94 p/u and i was puting on shackles and crankin my t-bars today and when i got ready to go drive it, it wouldnt start. so i checked the under the truck and made sure i didnt hit any gas lines or something then checked the efi fuse and it was blow. i dont no why it blew and when i put a new fuse in it starts up and sounds like it has a heavy duty cam in it. when i drive it i give it gas and it bogs down and sputters real bad. i give it gas and it seem like the clutch is goin out on it it kinda wines up and grabs sometimes. The clutch is new maybe 5000 on it but it seems like the engine is getting gas just no getting spark i checked all the wires and plugs and they all had good spark. im not sure what the heck goin wrong it seems like problem after problem with my poor yota. anyone have the same problem?
Old May 21, 2007 | 07:46 PM
Swansen's Avatar
hmm, well after just crankin on the torsion bars, doesn't seem like it would cause any mechanical problems, but it kinda sounds like the EGR valve is stuck open or closed. You didn't say if a check light was on or not, so i'm ruling out the bad VAFM. If it bogs down after you get on it, i don't think it would be a fuel filter or a plugged converter.
Old May 21, 2007 | 07:51 PM
hey thanks they check engine light is not on and i have no cat. the check engine light has been coming on alot ever sesnse i put the header on because the wires got messed because they were resting on the header and they melted. could a 02 sensor make all that much difference
Old May 21, 2007 | 08:02 PM
Swansen's Avatar
no, the O2 sensor would just mess with your mileage, not really effect anything performance wise, it didn't mess with mine at all. That said, what wires melted??
Old May 21, 2007 | 08:07 PM
Just the wires coming out of the O2 sensor. i dont think any other wires are damaged. i just cant figure out why the fuse just blew then it started running so bad.
Old May 22, 2007 | 06:24 AM
Swansen's Avatar
oh wait, so a fuse blew, thats what your problem was? Ok, so did you fix the problem or no?
Old May 22, 2007 | 06:29 AM
gametom's Avatar
i have a similar problem i was told by a mechanic it might be leaky injectors
Old May 22, 2007 | 11:01 AM
onced i replaced the fuse the engine started running really rough and sounded like it was running on 3 cyclinders. im gonna pull the injectors off today a check them out and clean them thanks guys
Old May 22, 2007 | 01:59 PM
Swansen's Avatar
yeah, i'd check to see if you have spark before you do all that.
Old May 22, 2007 | 02:40 PM
toyota_mdt_tech's Avatar
CHeck the oxygen sensor wires. They sometimes short to the exhaust (area you were just at) and can melt and the heater circuit will blow the EFI fuse. Also, wire harness that lays across the top of the fuel rail, will eventually chaffe to ground and also blow the EFI fuse.
Old May 22, 2007 | 05:55 PM
axon's Avatar
just had a similar problem. My O2 wire dropped were slowly ripped apart by the drive shaft. First the EFI blew, put a 30 amp in to get it home but on the way home the CEL code 21 came on. Got under the truck to check the o2 sensor and found the torn up wires. Splice all the wires back together and all is good now.
Old May 22, 2007 | 05:58 PM
thanks guys im goin to make sure the wires are good right now
Old May 23, 2007 | 09:08 AM
mudpunisher's Avatar
check the distributor cap too
Old May 25, 2007 | 07:31 PM
i found that the oxygen sensor wires were frayed and touching so i spliced them and the trucks running perfect now thanks for the help!!
Old May 26, 2007 | 02:08 AM
TNRabbit's Avatar
Glad you were able to fix your problem...enjoy!
Old May 31, 2007 | 01:37 AM
Allen's Avatar
My brother is also having the same problem... I guess, I have to tell him to check his Chevrolet oxygen sensor, if it has some faulty wiring that caused his efi fuse to blow... Really feel excited what I had found, because his been wondering what was the cause for days now... Can't wait to tell him tonight... Thanks guys....
steve miller
Oct 10, 2015 01:40 AM
Yota.Jay
Jul 23, 2015 08:08 PM
Jnkml
Jul 6, 2015 01:20 PM
wilbertd
Jul 6, 2015 07:39 AM
