Dropping The Fuel Tank
My leak is above my fuel tank. Can one of you outstanding peeps post some quick instructions, or a pdf reference on how to drop the fuel tank in my 4 runner, so i can get at the brake lines ???
6 bolts hold the skid plate up to the bottom of the tank. 6 more bolts hold the tank up to the frame brackets. Lower a bit and disconnect the level sender and pull the pump out or disconnect the lines to it. Tank can be drained if needed by removing the drain plug at the bottom rear.
Thanks... just needed a quick low-down....
If anyone has anything else to add.. tips and tricks, let me know.... few hours from now i will doing this.
unless you have a floorjack to hold the tank, drain it before you drop it..
I've literally had to drop my tank about...10 times.
various stupid reasons..
Just dont smoke a cig while your draining it or anything...that would constitute as a good tip
Definitely drain the tank or run it down- not for lowering but it's a bear to get back in with any amount of fuel in it. Like others have said 6 bolts on the skid, 6 on the tank. On my '92 the access panel under the back seat (4runner) lets you disconnect the plug to the pump and main fuel feed. Be aware there will be residual pressure in the fuel line. You will also need to disconnect the low pressure vent and return lines.
Good luck.
Good luck.
pyramid
Jul 30, 2015 10:05 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
