Dropping The Fuel Tank
Old Nov 28, 2008 | 04:09 PM
skinnadoor's Avatar
My leak is above my fuel tank. Can one of you outstanding peeps post some quick instructions, or a pdf reference on how to drop the fuel tank in my 4 runner, so i can get at the brake lines ???
Old Nov 28, 2008 | 04:29 PM
4Crawler's Avatar
6 bolts hold the skid plate up to the bottom of the tank. 6 more bolts hold the tank up to the frame brackets. Lower a bit and disconnect the level sender and pull the pump out or disconnect the lines to it. Tank can be drained if needed by removing the drain plug at the bottom rear.
Old Nov 28, 2008 | 04:31 PM
slacker's Avatar
fuel tank has 6 bolts holding it in .. under the skid plate
remove the fuel filler tube bolts .. and remove the 6 bolts .. and lower the tank .
Old Nov 28, 2008 | 05:17 PM
skinnadoor's Avatar
Thanks... just needed a quick low-down....
If anyone has anything else to add.. tips and tricks, let me know.... few hours from now i will doing this.
Old Nov 28, 2008 | 05:24 PM
scuba's Avatar
unless you have a floorjack to hold the tank, drain it before you drop it..
I've literally had to drop my tank about...10 times.
various stupid reasons..
Just dont smoke a cig while your draining it or anything...that would constitute as a good tip
Old Nov 28, 2008 | 06:15 PM
Bigblock's Avatar
Leave the tank in and run a new line around the tank.
Bigblock
Old Nov 28, 2008 | 07:01 PM
toyminator2000's Avatar
I think there is an access panel under the rear seat to the fuel tank. check as see if you can see where it is leaking from.
Old Nov 28, 2008 | 08:26 PM
Hophead's Avatar
Definitely drain the tank or run it down- not for lowering but it's a bear to get back in with any amount of fuel in it. Like others have said 6 bolts on the skid, 6 on the tank. On my '92 the access panel under the back seat (4runner) lets you disconnect the plug to the pump and main fuel feed. Be aware there will be residual pressure in the fuel line. You will also need to disconnect the low pressure vent and return lines.
Good luck.
Old Nov 29, 2008 | 03:14 AM
Bigblock's Avatar
There is no access panel unless you make one!
Bigblock
Old Nov 29, 2008 | 10:37 AM
just a 22re's Avatar
yeah i just ran new lines around the tank why go though all the problems of droping it just to do the same thing?
Eggslinger
Jun 8, 2019 03:32 PM
Doug4320
Mar 24, 2018 10:11 PM
pyramid
Jul 30, 2015 10:05 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
shisha1999
Jul 13, 2015 11:09 PM
