Do our stock temp gauges go bad or usually the sender?
Old Jan 24, 2011 | 06:28 AM
Ilovemountains's Avatar
Question Do our stock temp gauges go bad or usually the sender?
My temp gauge jumps to the midpoint about 30 seconds after I start my truck, which can’t be accurate; it was 15 degrees outside this morning! Anyway, do you think the gauge sending unit could be the culprit or the gauge itself? My truck is an 88 3.0 with full gauges by the way.
Old Jan 24, 2011 | 06:35 AM
waskillywabbit's Avatar
My bet is sending unit or wiring.
:wabbit2:
Old Jan 24, 2011 | 06:38 AM
cracker_1's Avatar
X2 on sending unit or wiring, as the gauges usually do not have issues.
Old Jan 24, 2011 | 06:46 AM
Lextech's Avatar
I have the exact same issue, but became too lazy to look into it. I have an '88 4Runner with a 22RE, equipped with a 3.0 gauge cluster though (was free)...
Old Jan 24, 2011 | 07:01 AM
Calling Autozone now to see if they have a sender, I just replaced the hoses, thermostat, radiator and the coolant temp sensor for the ECU so this sender would be just about everything! Ill let you know if it fixes it...
Old Jan 24, 2011 | 11:56 PM
myyota's Avatar
Ive had the temp sending unit go bad and cause the gauge to read some times or not at all.
Old Jan 28, 2011 | 05:28 AM
No luck, I put a new sending unit in and it now it still jumps right to the center of the gauge... Any ideas? The connection had never been apart and was still clean so I doubt its wire related.
Old Jan 28, 2011 | 08:53 AM
cracker_1's Avatar
Check your ground to the instrument cluster, might be another possibltiy then. Do you have another gauge to try?
the1998sr5
15
Jul 14, 2020 08:35 PM
gary4runner
Sep 24, 2015 12:53 AM
Jeffreynmandy
Jul 18, 2015 08:26 AM
Poncho0206
Jul 10, 2015 06:21 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
