Dirty, Nasty Head
Old Feb 17, 2009 | 03:35 PM
874runnersr5's Avatar
Originally Posted by muddpigg
These engines are a non-interface type, so even with the timing chain slipping no valves or pistons were touched.
You sure about that?
22re is a interference engine
Old Feb 17, 2009 | 03:36 PM
https://www.yotatech.com/forums/f2/2...uestion-71733/
Old Feb 17, 2009 | 03:37 PM
desconhecido's Avatar
Originally Posted by mt_goat
X2...did you pick this up in New Orleans 9th ward?
That's funny. It does look like flood damage, doesn't it?
My concern with flushing it out with solvent/atf/whatever is that dirt, grease, and grime probably comprise a large portion of the bearing surfaces.
Old Feb 17, 2009 | 03:46 PM
desert-rat660's Avatar
maybe a couple of the valves burned, could be the cause of the compression loss
Old Feb 17, 2009 | 03:49 PM
  #25
I think the major cause of the compression loss is that the cam is about 45 degrees out of time with the crank. But, I'll probably end up doing a valve job on it anyway.
  #26
RMA's Avatar
RMA
Just pull it and rebuilt it , it will start , does look nasty tho.
Old Feb 17, 2009 | 03:55 PM
  #27
might aswell 22re parts arent that expensive, and atleast you only have 8 valves to deal with
Old Feb 17, 2009 | 05:28 PM
  #28
muddpigg's Avatar
http://www.lcengineering.com/Inst/1022027.htm Last paragraph explains the process to insure that it is a non-interfacing engine.
http://race-dezert.com/forum/archive...p/t-43735.html but this says depends on year and piston. But goes on to say that it is still unlikely to happen. But I don't know.
I still say chage time chain and cover. Spin the engine by hand to see if any valves a obviuosly stuck. See if it starts if so tune-up and frequent oil changes maybe a flush. And run it. If it runs you've got less tha a hundred bucks in to it. If you pull the head you have to replace HG and the price starts to increase. If it don't run and you rebuild you already got a new timing chain and cover.
Old Feb 17, 2009 | 05:45 PM
  #29
iamsuperbleeder's Avatar
wow... I've seen, and taken apart some dirty motor's insides before in the past, but I think that tops the cake man...
Old Feb 17, 2009 | 05:48 PM
  #30
hmm, i think this is going to be one of the questions that never get answered haha.
either or, better safe then sorry no?
Old Feb 17, 2009 | 05:55 PM
  #31
muddpigg's Avatar
Think your right. May have been unscathed but my have bent every valve in the head. I don't know.
Old Feb 17, 2009 | 06:06 PM
  #32
ah, thats so insane thoe.
i cant belive its that dirty... to only think what the pan looks like, the crank, timing cover area.. the oilpickup tube..
Old Feb 17, 2009 | 06:07 PM
  #33
oh yes, you must post more pics of this process...
Old Feb 17, 2009 | 07:44 PM
  #34
check to see how the rad is, im assuming it was ran just with water...
Old Feb 17, 2009 | 10:09 PM
  #35
taylordog2's Avatar
all i have to say is WOW!!!! i thought that mine was bad when i got it....it looks new compared to that!!!!!
Old Feb 17, 2009 | 10:22 PM
  #36
It's got four new plugs, clean oil and fresh antifreeze. Probably all done trying to get it running after it jumped time. So, if the head gaskets gone (which is possible) or the timing cover has warn through, there' no obvious evidence till I get the front end apart.
I've got some old stuff I need to get sold on ebay and then I'm going start in in the engine. I'll post some progress picks, for those with strong constitutions.
Eggslinger
Jun 8, 2019 03:32 PM
Dakotaneu
Aug 15, 2015 07:24 AM
yourrealdad
Jul 29, 2015 11:08 AM
jjrbus
Jul 19, 2015 02:06 PM
the1998sr5
Jul 16, 2015 06:20 AM
