Differential Education
Old Jan 8, 2010 | 06:41 PM
90RunnerRed's Avatar
Originally Posted by raydouble
They should be able to tell you the OEM flow of a new injector and what the other 3 are at....then go from there.
Pinion seal, drain or fill plug and axle seal......or hole in housing.
Sounds like the pinion seal if it's getting flung.
I'd get under there and shake the pinion flange, should be zero up and down or side to side movement.
If it's got movement the flange nut may have gotten backed off, crush sleeve got more crushed, or pinion bearing toast (doesn't take much leaking to starve the pinion bearing of lube.)
If it's coming from the pinon it could be as simple as the breather being plugged too. Worth checking out.
Old Jan 8, 2010 | 07:29 PM
raydouble's Avatar
Originally Posted by abecedarian
The point being there's no way of knowing that the 'new' injector will flow the same as the 3 other balanced injectors... unless the new injector is purchased from the same place balancing the other injectors and all 4 are being compared.
Fair point and very true.
Why didn't they ask for the 4th injector?
Old Jan 8, 2010 | 07:36 PM
Jipopotamo's Avatar
Ok well then if the vehicle expenses are not as severe, I would be just as interested in some new shop equipment. I am really eyeballing a shop press, a 6 ton from harbor freight. I feel like a shop press may be something that I will find a use for again and again and it will allow me to take care of just about all aspects of my own vehicle. Any sense in it?
Cale
ashamsuddin
17
Jul 22, 2024 03:59 AM
justdifferentials
14
Jun 11, 2017 08:36 PM
pickle6415
Oct 19, 2015 08:08 AM
voiddweller
Oct 2, 2015 07:47 AM
Odin
Sep 26, 2015 06:56 PM
