Dash Question
Old Mar 28, 2008 | 02:01 PM
dewitt88's Avatar
Dash Question
I have a 1988 Toyota Pickup Reg Cab 22R. I have been recently restoring..
Complete Frame Overhaul
Emissions Gone
Weber 38
Header
Timing Chain
Head
So on and so forth.
Fully primed grey
Ok so I am now on the inside and I have all the interior out nothing left but the column. Will a 90's model dash go in? I searched and found nothing. Thanks
Old Mar 28, 2008 | 02:38 PM
85toy's Avatar
I dont think so.
Old Mar 28, 2008 | 02:50 PM
dewitt88's Avatar
I understand that it will not be a direct fit but if its worth it I would be willing to try to make it work. Just curious...If not I will but custom painting the new dash for the truck and wrapping the door panels in something. I will figure it out I was just curious if anyone knew?
Old Mar 28, 2008 | 09:21 PM
standardbyker88's Avatar
ive heard that its possible. i have a 92, i can get some measurements of it. in fact, tomorrow im going to the junkyard to get a new upper for mine, ill take pictures of it as i get it apart. then you can see if its similar in mounting. i know the top is little tabs into holes, and there are a few tube bars side to side for mounting things. i keep trying to get my buddy to do it to his 88 2wd.
Old Mar 29, 2008 | 06:30 AM
dewitt88's Avatar
Yeah that would be cool. I am just playing with options at this point. If I can't get it to work I will just get some paint and use my imagination
Just wanted to try it and see what I could come up with. Off to the junkyard I go to see what I can find
Old Mar 29, 2008 | 01:56 PM
dewitt88's Avatar
Ok fellaz NO this will not work. It does not line up and is diffrently shaped that the inside of the cab. Support for the dash is ALOT diffrent. I went and pulled a dash out of a 92 and its MUCH diffrent.
So I repainted my interior and it looks much better. Thanks
Old Mar 29, 2008 | 06:57 PM
sh0kk86's Avatar
would you have access to the door panels to see if it could be made to fit? like the 92 into an 86?
Old Mar 30, 2008 | 01:58 PM
they cant be that much different. just recover yours. the handles and cranks are about the same. arm rest might be different. but im talking base vs base. i know some plusher ones had a top portion over the painted area.
ashersullivan88yota
Jan 18, 2022 05:37 PM
mussy01
Dec 13, 2016 08:20 PM
ViperTT
Aug 14, 2015 05:27 AM
icentropy
Jul 14, 2015 10:23 AM
jetspeedz
Jul 13, 2015 09:32 PM
