in dash brake light
Old May 6, 2006 | 01:01 PM
93tojo's Avatar
in dash brake light
Well when i was changing my brake pads i discovered my driverside caliper was shot. i replaced it and blead the brakes good and all that, but my brake light in the dash is still on and i cannot figure out how to get it to go off. the brakes work great i have never had better breaks so i have no clue.
Old May 6, 2006 | 01:16 PM
VA_Yotaman's Avatar
Do you think the brake light is directly related to the front brakes? Does your truck have cruise control? If so, does it work? If not, unplug the "dummy light" on top of the brake resevoir cap. Mine went bad, and the light stayed on.
Old May 6, 2006 | 01:17 PM
93tojo's Avatar
can someone please tell me how to get rid of this gay a$$ light
Old May 6, 2006 | 01:18 PM
93tojo's Avatar
no my truck does not have cruse and the light didnt come on until i changed the caliper so i guess it is the front brakes.
Old May 6, 2006 | 01:20 PM
Jimmeh's Avatar
What year and model of truck?
https://www.yotatech.com/forums/f116/brake-light-82076/
I have the same problem...still.
Old May 6, 2006 | 01:29 PM
93tojo's Avatar
its a 93 pickup 4wd, i would normally look in the trouble shooting guide in the repair manual but i loaned it out and dont have it to reffer to.
Old May 6, 2006 | 01:36 PM
dieselhound's Avatar
Mine done the same thing. I filled the reservoir up and it didn't go out. I cleared the code. I pulled the positive and negative terminals off and touched them together. It cleared out and all is good.
Old May 6, 2006 | 04:25 PM
Did that work??
Old May 6, 2006 | 06:08 PM
93tojo's Avatar
well how will i clear the code, wont i have to have a scanner or something? and i disconnected the battery and reconnected it and it still is there.
Old May 6, 2006 | 06:14 PM
Yes, but you have to ground the positive side. I have tried to just disconnect the battery but, that did nothing. If you touch them it completely grounds the CPU and system. I know you have heard this before-just trust me. It will clear all codes. Only the hard codes will remain.
Old May 6, 2006 | 06:46 PM
93tojo's Avatar
awsome i will try it right now
Old May 6, 2006 | 06:58 PM
93tojo's Avatar
it still remains.
Old May 6, 2006 | 07:05 PM
You touched them together?
Old May 6, 2006 | 07:33 PM
93tojo's Avatar
well i got it this time. YESSSSSS! thanks man i really appreciate it, and everybodies help on this it was driving me crazy.
Old May 6, 2006 | 07:37 PM
What did you do?
Old May 6, 2006 | 07:42 PM
93tojo's Avatar
i pulled off both of them at first and touched them togather and it didnt do anything, so i pulled off the positive and touched it to the negative, reconnected the positive and pulled off the negative and touched it to the positive and i think that did it.
Old May 6, 2006 | 07:45 PM
That cool. You got it
Old May 6, 2006 | 07:46 PM
93tojo's Avatar
now do you have any idea where i can get one of these? i think its like a vsv or pvp or something?
Old May 6, 2006 | 07:52 PM
I really can't see it. Can you get a closer picture?
Old May 6, 2006 | 08:12 PM
93tojo's Avatar
yea i will try to get a better pic tomarrow. i can prolly get one at a junk yard or they might not be that much at a dealership so i will call and check. thanks man
ashersullivan88yota
Jan 18, 2022 05:37 PM
jasonty
41
Dec 23, 2018 01:00 PM
fountain
Dec 31, 2015 06:08 AM
Sandman
Jul 14, 2015 12:36 PM
Johntom240
7
Jul 13, 2015 12:18 AM
