Crankshaft Pulley Bolt
Old Feb 13, 2009 | 09:35 AM
  #41
GSGALLANT's Avatar
Originally Posted by 89whitetoyota
Does the breaker bar on the frame with a 1/2 inch 19mm, and engine crank only work for 22r?
It also works for the 3.0 and the 3.4, but again, you can't use that method to torque it back up, so in my mind, I don't understand why somebody would bother doing it that way.
Old Feb 13, 2009 | 09:53 AM
  #42
surf4runner's Avatar
Originally Posted by mudhoney
....fill hole with oil and put plug back in...
interesting way to use hydraulics!
after breaking 2 impact guns + a few sockets, mine was chiseled off.
Old Oct 8, 2009 | 06:09 PM
  #43
Dam-it-wicks's Avatar
Does any one know how to remove a Crank pulley bolt that has lost its threads and turning and would not come out? please help
Old Oct 9, 2009 | 02:54 AM
  #44
mt_goat's Avatar
Dang, that sounds like a nightmare. So its turning but won't back out? Have you tried prying with a big screwdriver while turning lefty loosey?
Old Oct 9, 2009 | 04:06 AM
  #45
ayoung101's Avatar
another trick is one i used to get a stuck lug nut loose once. it might work for the crank bolt too. put on the breaker bar/ratchet with the bar off to the right, put a jack underneath the bar. lift the jack. the bar goes up with the jack, forcing the bolt counter-clockwise with a lot more force than your bicep could give. you're gonna have to have it in gear with someone stomping on the brakes for this. i can take a picture of you don't follow what i'm saying.
Old Oct 9, 2009 | 06:24 AM
  #46
Crankshaft Pully Bolt
I have tried Pryng but no answer. Can ayoung101 send me picture as I cannot undestand
Old Oct 9, 2009 | 06:59 AM
  #47
mt_goat's Avatar
Are you sure the crank is not turning and the bolt is? I don't think ayoung101 was even answering your question, your problem doesn't seem to fit his suggestion.
Old Oct 9, 2009 | 08:06 AM
  #48
ayoung101's Avatar
maybe i misunderstood your problem, but i took it to mean that you just can't get the crank pulley bolt broken loose so you can remove your pulley. the method i described was not for a crank pulley bolt, but it MIGHT work. i mean, a stuck bolt/nut is a stuck bolt/nut. so this is what i did one time with a stuck lug nut. i just used the power of a hydraulic jack to force the bolt/nut to turn instead of using muscle power. in the case of a crank pulley bolt, on any engine where the crankshaft isn't locked up, doing this will easily turn over the entire engine before loosening the bolt. which is why i said to put the trans into 5th gear (assuming stick shift) and have someone hold the brake pedal so nothing can turn except the bolt. good luck. if you have any other questions, PM me, cuz i might not see that you asked otherwise.
Old Oct 9, 2009 | 08:22 AM
  #49
ayoung101's Avatar
yeah my bad i was answering the ORIGINAL question of the thread, not your question about the stripped bolt. upon re-reading it, i noticed that this thread is 2 years old. hahaha, why are we still talking about it? as for you, i'd recommend starting your own thread. sorry i can't help more.
eggens
Sep 5, 2015 12:16 AM
Aaron Logan
Sep 3, 2015 08:08 AM
Ryall
Sep 2, 2015 06:48 AM
romex1
Aug 10, 2015 06:21 PM
yoterr
Jul 24, 2015 04:29 AM
