Clutch Lines
Old Oct 2, 2024 | 02:05 PM
Eighthnote's Avatar
Clutch Lines
Hello all, I just ordered the master and slave for my 1993 4X4 SR5 pickup. I might as well replace all the lines during the repair. Question: Would anyone be so kind as to point me towards a diagram and/or part list that would show me the way? Much appreciation. The more info the better............................Cheers.......... .........
Old Oct 2, 2024 | 08:46 PM
millball's Avatar
Everything is revealed here>> Toyota parts catalog (epc-data.com)
Old Oct 7, 2024 | 11:09 AM
Eighthnote's Avatar
Need help. I replaced the master and slave clutch cylinders. Bled the air out. Truck drove fine for 12/15 miles then I started having the same problem. Pedal to the floor and can't shift. Checked fluid and it was very low. I do not see leaks. No fluid under the truck. Where could my fluid be going? With a full reservoir the truck runs and shifts good. It just doesn't last. Any advice would be much appreciated. Thank you,
Old Oct 7, 2024 | 02:22 PM
prcnctoyo's Avatar
You mention no fluid under the truck... Did you check the driver's side floor for fluid?
Old Oct 7, 2024 | 05:36 PM
Eighthnote's Avatar
Success
Hopefully I've fixed it properly. The soft hose in the middle of the hard line to the slave cylinder was leaking. A clamp from another hose under the hood had worn a hole in it. It was a pain to find one locally and it was a bigger pain to take it apart and fix. Buried underneath all kinds of AC and EGR and vacuum hoses. If I wouldn't have jumped to the conclusion of bad master or slave cylinders I would have saved a lot of time and work.
Old Oct 8, 2024 | 06:49 AM
Jimkola's Avatar
YT Community Team
5 Year Member
Thank you for posting what fixed it. That's worth a lot.
Old Oct 8, 2024 | 11:27 AM
Eighthnote's Avatar
Soft Clutch Line
Here's the part that will eventually need replaced. In my case a hose clamp from another line wore a hole through it causing the failure.
CAPTDASH
Sep 24, 2012 03:34 PM
BRODAVE
Feb 4, 2012 12:04 PM
marsstar102
Jun 27, 2011 04:14 PM
descendents
Mar 31, 2007 02:03 PM
descendents
Dec 11, 2006 09:10 PM
