Climate control panel bulb s14w
Old Apr 24, 2024 | 04:07 PM
mister_floyd's Avatar
I'm not having any luck locating a replacement bulb for the climate control panel in my 1987 SR5. Has s14w on the old bulb. Any suggestions?
Old Apr 24, 2024 | 05:37 PM
Jimkola's Avatar
YT Community Team
5 Year Member
i got a LED bulb. I'll see if I can find the info
Old Apr 29, 2024 | 09:01 AM
RAD4Runner's Avatar
YES PLEASE, Jim. Also need to replace mine. Figured an LED would last much longer. TIA
Old Apr 29, 2024 | 05:45 PM
Discombobulated's Avatar
I don’t know if the Climate panel is the same as a 91 but this fit my truck, I tried the single LED that faces forward and it didn’t reflect through the plastic panel left and right and had a major hotspot, so I went with the 3 led one and used I little butyl to block the front facing bulb, on the plastic not the bulb(if that makes sense) it works great, very bright and even. But again this is on my 91……superbright bulb number is just type 74…..
The specs are on the site, I’m sure you can measure your old bulb and see if the dimensions will work.
https://www.superbrightleds.com/74-l...ure-wedge-base
Old May 6, 2024 | 08:54 AM
I have found the correct bulb!! Thanks to a previous post titled 87 HVAC Control Switch Bulb... The correct bulb is Sylvania 2721. Thanks to that sub and thanks to those who offered suggestions!
Old May 12, 2024 | 11:20 PM
WandaPapke's Avatar
Thank you so much for sharing the link.
Spoiler
Dawsonmarch
Feb 26, 2024 04:02 PM
GrimWolf
May 20, 2019 07:03 PM
chad99
11
Sep 26, 2007 09:02 PM
crappled
Oct 25, 2005 10:29 AM
Steveh29
Jan 31, 2005 06:35 PM
