check engine light help no code id
Old Jan 24, 2008 | 11:42 AM
stevec8720's Avatar
ok i have a 1995 p/u 22 re and i tryed clearing the cel. disconnected the battery for 10 minutes both terminals. the second i start its back on. the code for it is 2 blinks pause then seven blinks i checked a few times same thing. what does that mean. theres no code for that in my book. help please! anything helpful would be appreciated. thanks
Old Jan 24, 2008 | 11:52 AM
thook's Avatar
Try this link:http://www.off-road.com/toyota/tech/codes/index.html
There aren't any codes that aren't covered somewhere.
Old Jan 24, 2008 | 11:58 AM
Elvota's Avatar
You have a code 27.
Old Jan 24, 2008 | 12:00 PM
stevec8720's Avatar
yea whats the code mean tho i dont see what it means anywhere. what kind of malfunction is it
Old Jan 24, 2008 | 12:03 PM
applesauceman5's Avatar
I hope you have a California vehicle. A code 27 is the sub oxygen sensor which is only on CA vehicles. It's the oxygen sensor behind the cat.
Old Jan 24, 2008 | 12:04 PM
MSR's Avatar
MSR
sounds like your after cat o2 heater went bad. Disconnect the sensor and check resistance across the two similar color wires usually white or black little or no resistance good, open bad
stevec8720's Avatar
SUB-OXYGEN SENSOR CIRCUIT OR SUB-OXYGEN SENSOR HEATER CIRCUIT
--SUB OXYGEN SENSOR/HEATER/CIRCUIT
--ECU
so o2 sensor then. change the one before or after the cat?
Old Jan 24, 2008 | 12:05 PM
MSR's Avatar
MSR
after
stevec8720's Avatar
opps thanks for the help
Old Jan 24, 2008 | 01:20 PM
stevec8720's Avatar
thanks for the fast replies. now is it possible to put some sort of resistor in the connector like how the egr mod is done just curious. this way i dont see that stupid light while im waithing on the sensor.
Old Jan 24, 2008 | 01:30 PM
stevec8720's Avatar
anyone
Old Jan 24, 2008 | 03:55 PM
thook's Avatar
Nope. But, you could always put a piece of tape or groovy sticker over it.
sonic concepts
Aug 16, 2025 03:13 PM
rbravo1
Jun 29, 2015 01:34 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
94hiluxZE
Jun 22, 2015 10:42 AM
Mutinebullfrog
Jun 18, 2015 01:36 PM
