A/C conversion: what will fit?
Old Oct 12, 2015 | 03:32 AM
ashamsuddin's Avatar
So my junkyard sells the whole AC system for $130. Seems worth it even assuming I'll need new parts to get it to actually work. So what years are compatible with my '87 carbureted pickup?
Old Oct 12, 2015 | 06:56 AM
Janos01's Avatar
Just go with factory A/C. Rock Auto sells NEW factory compressors from DENSO.
Old Oct 12, 2015 | 07:34 AM
scope103's Avatar
I think he's looking for ALL the parts ... compressor, condensor, evaporator, air box ...
You will always need to replace the drier, and almost certainly the Expansion valve. You'll need to flush out each component; no telling what's inside (could be parts of a disintegrated compressor) Also, you're not going to charge it with R12 (WAY too expensive), but since you're reassembling all the parts using the right o-rings is a snap, so R134a is the way to go.
Good luck!
Old Oct 12, 2015 | 01:13 PM
Terrys87's Avatar
84-88 should work just fine for you. The 89-95 might work but not sure on that.
Old Oct 12, 2015 | 02:15 PM
Nervo19's Avatar
You would be a popular and worshipped man if you would do a tech thread on how you do it. I've still got all the parts in a box in the garage.
Old Oct 14, 2015 | 08:40 AM
punks_is_4x4's Avatar
Please go for it if u need factory stuff let me know my brother is the parts guy so I can get u a list of all the factory stuff. He said for parts at his price was just under 500!! Heard of shops charging 2k for full installation of aftermarket system
Old Oct 14, 2015 | 08:41 AM
I want to ad it to my 95 my 87 has a working system all original surprised it held up
Old Oct 15, 2015 | 04:24 AM
Terrys87's Avatar
Here is a thread that will help with the Evaporator https://www.yotatech.com/forums/f116...trucks-286766/
There is two dimples in the fire wall that the lines that poke thru for the Evaporator. Use a coned drill bit for better results but at the time I had some old wood drill bits that I wont be using and was available.
Inside the cab floor board there is another dimple that is for the drain hole for the Evaporator that needs to be drilled.
You will need to add Condenser and Compressor pump. I am slowly gathering things to add to my trucks and when I get them gathered up, I will create a thread on installing an AC system.
ADDED to show how to get the cover and heater control switch out. This thread can be used to do other things https://www.yotatech.com/forums/f116...4-88-a-278925/
The dimples are easily seen when you look at your firewall. ( I am sure the tool I used is not Toyota approved, but it worked, lol)
Old Oct 15, 2015 | 08:26 AM
Do you mean all the parts new for $500? Or do you mean ripped out of an old truck? If it's ripped out, I'll just do it myself so I know where everything goes. I want to do this, but I'm afraid. Do I have to tear out the whole dash for this?
Old Oct 15, 2015 | 11:16 AM
Terrys87's Avatar
You don't have to take out the whole dash to do it. Getting AC plug into the control might take a little work but it shouldn't be to bad. Just remove the cover, undo the screws that hold the heater controls in.
In my previous post under the ADDED it will show how to access the heater control to add the AC Button.
Old Oct 15, 2015 | 05:24 PM
500 new so I was looking at it like that because I don't want to have to buy any more vehicles for my family I plan to keep my truck a daily as much as possible and my wife's will only be a daily so adding 500 bucks to a car I'm gonna have for hopefully ever and have brand new ac that will hopefully stand up another 300k if u can do it for way cheaper I'm going to copy you haha!
Old Oct 16, 2015 | 04:12 AM
I agree with you. $500 is not a lot. I'm definitely interested. Please PM me or post the information. Your "brother" is not a Nigerian prince that I'll have to wire money to, is he?
ToyotaMD
Aug 17, 2018 10:16 PM
irv
Sep 23, 2015 08:30 AM
ToyotaMD
Sep 22, 2015 04:49 AM
Obmi
Sep 21, 2015 05:17 AM
Bowman5115
Sep 19, 2015 03:04 PM
