broke out a lift block now fixed and no brake pressure!!!!
Old Apr 21, 2010 | 08:19 PM
tferro253's Avatar
ok like the title says last weekend i was wheeling at my lift block broke and my leaf springs came apart long story short i towed the vehicle home and got a new lift block kit and got everything squared away. however know my brake pedal has no pressure the brakes work but not very well. i can pump the brakes and they have pressure but only for a few seconds. i have tried bleading the brakes several times and have looked everywhere for leaks i cant find any. can anyone help me with this?
Old Apr 21, 2010 | 08:27 PM
yotaman85's Avatar
check to make sure your drums are adjusted. I had this happen and didnt even know tell i hit the street.
Old Apr 21, 2010 | 08:32 PM
tferro253's Avatar
i checked the drums even put new shoes in there today
Old Apr 21, 2010 | 08:39 PM
dropzone's Avatar
Fossilized
check for kinks...did you inspect the LSPV? connects to the rod at the axle and is mounted on the passenger side of the frame above the Right rear wheel
Old Apr 21, 2010 | 08:41 PM
tferro253's Avatar
yea my friend suggested i check out the lspv i looked at it didnt see any leaks anything else i should check on it.
Old Apr 21, 2010 | 08:46 PM
dropzone's Avatar
Fossilized
bleed brake in this order: RR->LR->RF->LF
if the fluid in the master cylinder got too low you will need to bench bleed the MC...
Old Apr 21, 2010 | 08:47 PM
tferro253's Avatar
fluid in the master cylinder stayed high. could i have pinched a line and fluid comes through when bleeding but not in operation?
Old Apr 21, 2010 | 09:07 PM
tferro253's Avatar
bleed the brakes in that order went around twice and know difference.
Old Apr 21, 2010 | 09:14 PM
allnmstkn313's Avatar
Check again for leaks. If you press down the petal and then slowly lose pressure you have a leak somewhere.
Old Apr 21, 2010 | 09:20 PM
tferro253's Avatar
here is something else that seems odd to me when the truck is off and you pump the brakes everything is good has good pressure. when you turn the truck on the brakes seem fine but when you put it in gear and rolling it goes to the floor.
Old Apr 21, 2010 | 10:33 PM
DeathCougar's Avatar
Actually this is incorrect.
You bleed the wheel cylinder which is furthest away from the master first. Given that the brake line comes down the pass side frame rail, the Left Rear wheel cylinder is the furthest away, using the longest amount of line. So it should be bled LR > RR > RF > LF
bigjstang
Jun 2, 2025 03:56 PM
ashersullivan88yota
Jan 18, 2022 05:37 PM
Jun 1, 2021 01:51 PM
Jnkml
Jul 6, 2015 01:20 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
