broke my timing chain guide, time to rebuild (pics)
Old Apr 9, 2011 | 03:14 PM
  #161
RBX's Avatar
RBX
did the threads come out?
guess you will need to helo-coil(sp?)
Old Apr 9, 2011 | 03:34 PM
  #162
peow130's Avatar
If you broke it off above the head, pull the bolt with a pipe wrench. Go heavy on the PB blaster. If you shear it again in the head, drill and easy out, and pray you don't nick the threads..
Old Apr 9, 2011 | 03:39 PM
  #163
irab88's Avatar
the head is stuck on. it won't come off in the back
i'll get some photos up in a bit
Old Apr 9, 2011 | 03:53 PM
  #164
irab88's Avatar
the bolt
the stuck head
the small gap in the back
on a brighter note, i now have my radiator, fan, alternator adapter and bracket, and maybe some other stuff at home. more pics in the morning
Old Apr 9, 2011 | 04:15 PM
  #165
RBX's Avatar
RBX
Ian,
For future reference, when dealing with bolts/nuts use a snapping force like an impact, not a slow hard pressure. Of course, you can still have broken bolts either way, but this method should help avoid a broken bolt.
That's what I was always taught,not that there is always a choice either.
Old Apr 9, 2011 | 04:16 PM
  #166
peow130's Avatar
Something is still bolted down, or if it was anything like my truck, the bolt bassages in the head had crud in them that made them hard to get out
Old Apr 9, 2011 | 04:37 PM
  #167
irab88's Avatar
Originally Posted by RBX
Ian,
thanks. yeah, that bolt did not want to move. from taking everything else off, i knew that if i heard it snap, i was fine. but if it was like twisting cold clay, it would break.
i don't know of anything else holding it on. i'll look tomorrow and try to take off any bolts from the backside.
crud. i thought i was going to get away without shearing a bolt. at least i still have an inch or so to play with.
Old Apr 9, 2011 | 04:51 PM
  #168
92 TOY's Avatar
geez man....i just came across this thread and I saw it was you and holy hell you are in a bind. i did not read the whole thing......i will but i just don't have the time right now.
give me a brief run-down. manifolds are off right? head is held down by head bolts and the hidden one to the timing cover...did you get that one?
Old Apr 9, 2011 | 04:58 PM
  #169
92 TOY's Avatar
Ian......I just was looking at you pic of the above bolt......if I remember correctly (an you can confirm this by just looking at the bolts, that broken bolt will not be impeding you at all EXCEPT.....it does not look like you are pulling the head STRAIGHT UP but rather, at an angle and it is likely binding against the remaining shaft of the bolt..........make a gantry or borrow a lift and lift it straight out......or do what I did and get inside there and lift it straight out
Old Apr 9, 2011 | 05:22 PM
  #170
92 TOY's Avatar
okay....just skimmed the thread and it looks like i tuned in at the right time.
get your hood off.
lift that head straight up.
i'm spooked by how much your pics and y pics are the same.....color and all.....creepy
good luck man......i gotta get going....check ya tomorrow morning before work. i think you already mentioned it but make sure you read my "B" thread.
Old Apr 9, 2011 | 05:55 PM
  #171
irab88's Avatar
thanks. i think i can do that. it'll be an all-day project.
all 11 bolts are out, unless there is something behind the head.
so tomorrow: hood off, heater hoses off, head off (or else... (or else i'll wait 'til spring break))
also, i got in the engine bay where the radiator was, and tried to lift the head by hand. no joy.
thanks for the info, 92!
Old Apr 10, 2011 | 01:56 AM
  #172
92 TOY's Avatar
Ok....i'll check ya tonight. good luck
Old Apr 10, 2011 | 04:55 AM
  #173
irab88's Avatar
pics from yesterday:
my bolt layout board
finally got the wiring harness out
pile o' stuff, including head gaskets, front end kit, radiator, villager fan, alternator bracket, and alternator adapter
that stupid socket bolt. had to go get vice grips to get it off
reference pics
lower intake off
in order, 1-4
old and new alternator brackets
reference
alternator bracket out
i'll be painting the bracket with this
blowing on the pool of oil revealed the hidden bolt. and eventually found a piece of timing guide
how i wasn't able to move the bolt (#8)
yeah, ratchet straps
and these again
so, order of events today:
-lift head from centered above lift point
-if it comes off, cool
-pb blast the living daylights out of the un-threaded stud that was bolt #8
-try to vice grip it into submission, without stripping it. if i can do that, then i'll just need new head bolts, and all will be fine. i don't want to heli-coil
ian out
Old Apr 10, 2011 | 05:21 AM
  #174
Resto-noob's Avatar
Agree completely. Pipe wrenches are invaluable for this sort of thing. I used a pipe wrench with a cheater bar to remove the studs in my old exhaust manifold just the other day. Vise grips just chewed up the bolt. I also put Kroil on the bolts at least five or six times, which helped, I'm sure.
Old Apr 10, 2011 | 06:02 AM
  #175
irab88's Avatar
so if i understand correctly:
is better than
Old Apr 10, 2011 | 06:17 AM
  #176
Resto-noob's Avatar
You got it. Vise grips do have their place, though.
You also get a tool that can accept a cheater bar, which is a huge plus.
Old Apr 10, 2011 | 06:28 AM
  #177
irab88's Avatar
cool, thanks.
update: pulling straight up on the head yielded no better results. now it's just annoying.
Old Apr 10, 2011 | 09:02 AM
  #178
irab88's Avatar
head is almost off. it's about 3" off of the block, with maybe 1" left to go. it also took the better part of a can o' pb blaster and some hammering (not on the actual head or block). almost there...
Old Apr 10, 2011 | 09:15 AM
  #179
irab88's Avatar
the head is off!!!!!!!
Old Apr 10, 2011 | 09:44 AM
  #180
irab88's Avatar
got the #8 bolt out!!!!!!!!!
no heli-coil needed!!!!!!!!!!!
epic win!!!
so how'd i do it? i used a wrench the length of my arm is how. ftmfw.
