Break in process - quickquestion
Old Jan 13, 2011 | 08:27 AM
89whitetoyota's Avatar
From: Cincinnati, Ohio - Amelia is the exact place. There is no one else on this site from where I am. Seems like everyone is from Cali or Washington. I guess I need to move.
Being that this is not a flat tappet cam set up what is the proceedure for this on a new 22re with new head rings?
Old Jan 13, 2011 | 09:25 AM
MudHippy's Avatar
New head rings? I assume you mean new head and new piston rings, correct?
Flat tappet or not, the 22RE does require a specific cam break-in procedure. Which you could have easily found if you'd searched.
https://www.yotatech.com/forums/f116/22re-break-165608/
After the cam break-in, I highly recommend the "run it hard" break-in process for the rings. It's worked perfect for me.
http://www.mototuneusa.com/break_in_secrets.htm
One more thing, break-in oil. As in ZDDP. Add it to the oil, something like STP oil treatment. Or use a high ZDDP oil, something like diesel oil or oil labeled specifically as "break-in oil". And if you didn't already grease the cam lobes and rocker arms prior to initial start up, you might want to consider doing so.
RDubya
Feb 10, 2017 04:46 PM
Obmi
Oct 4, 2015 11:30 AM
voiddweller
Oct 2, 2015 07:47 AM
Brodetski
Sep 30, 2015 11:50 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
