Brakes slip and clunk then fine???
Hey everyone,
iv been trying to find someone on the site with my problem but no luck! if anyone has and input, please.
I have a 91 4runner and for the past month when i brake it will be fine but the the next push and the peddle slips then a clunk from the front????? iv bled the all 4 and the lspv... it brakes goods and everything but this feeling on the peddle and noise is a little scary.. i dont want to the brakes to fail on me.
any help would be great!!! Thanks
peddle slips
How often does this happen? Any witness marks on the front calipers or inside of the wheels? Are both caliper to knuckle mounting bolts still there?
ill have to check the rears, but as far as the fronts go its all in good order, but ill have another look on my days off.
angrybob: this happens every day, but not everytime i brake. it dosnt seem to effect my braking power, but i can tell when it is going to happen, feels good then pressed halfway in it will slip maybe an inch, and at the same time it slips i will hear a clunk from the front... but i continue to stop fast?
alright, so i pulled the drums off and the pads were fairly low witch was making on of the pistons over extend!!!! there was a drip of oil and the rubber boot was off alittle!!!!!! ahhhh,
i guess the piston over extending was making the clunk??? and having a hard time going back to normal position?
do i have to replace the piston??
ya just get a new piston, best to be positive it works when it comes to brakes
terminator
Jul 27, 2015 07:13 PM
Johntom240
7
Jul 13, 2015 12:18 AM
