Brake Light
Brake Light
My emergency brake doesn't work, which is no biggie because I don't ever park anywhere without leaving it in gear, but my brake light seems to come on a lot. All I have to do is mess with the brake lever, and it goes off. Also, it will keep staying on if I am low on brake fluid. And thoughts as to how I can fix this?
Add fluid, be sure you always have enough. Check your wheel cylinders/calipers for leaks if it continues loosing fluid. There is a switch behind the dash to indicate the parking brake is applied. Maybe lubricate the parking brake so it returns fully. If your parking brake doesn't work, get a FSM or Chilton's diagram and get under the truck and adjust it. It's not difficult.
Good luck
Good luck
See if the master cylinder float is sinking. It will give a false low on fluid and make the light come on intermittently, or if it's completely sunk, the light will stay on all the time. (Yer cruise control won't work with that light on, either)
The way to check is to disconnect the wires from the cap of the MC that plug into the harness. See if your light problems go away. If it's that, I think it's pretty expensive to replace that cap/float/sender unit.
Mike in AR
Mike in AR
Something to consider:
In a manual, internal damage can occur if your vehicle is hit while parked in gear. Since 1990, I have always left my vehicles left in 1st w/o the e-brake on, unless I was on a steep hill. Recently, my truck was hit while parked, and it caused tranny damage. Now, I only use the e-brake, unless on a steep hill. I do live on a semi-busy street though. I also leave my Dodge Intrepid in that same spot, hoping.
Just some food for thought.
Ever since I moved the spare to my roof rack, I've noticed that my (E)! brake light comes on, usually after I make a turn, as when I turn out of a parking lot onto the road. I jiggle the handle and it goes off.
I'm assuming that the extra weight up high is making the truck lean farther over, and slightly pulling (or pushing) the ebrake cable... I do have about 3" of lift in the back with Downey Coils and Blocks... been too lazy to really track down why it's coming on.
Here's the way I look at it: if you are on flat ground, and not a busy area, park in gear with no brake. This will save your brake from stretching the cable. On a hill or busy street, use both.
Mike in AR
ashersullivan88yota
Jan 18, 2022 05:37 PM
Sep 4, 2015 09:27 AM
Sandman
Jul 14, 2015 12:36 PM
Johntom240
7
Jul 13, 2015 12:18 AM
