Best Junkyard Mods
Old Nov 28, 2013 | 03:19 AM
  #461
Terrys87's Avatar
I add 1st gen SR5 chrome heater knobs to my trucks.
I use a standard cab light for 4Runners and Extended Cabs. The 4 Runners and Extended Cabs have a dummy light that holds the mirror mount. I tap into the wiring at the top left corner of the windshield.
I peeled the headliner back a little and slid it in. Then put the trimming back in to hold the liner back in place.
Then where the mirror goes I usd the mirror screws to hold it so I could cut the liner for the recess for the light assembly.
Here it is mounted. I still need to run the wiring. I have always added a standard cab pick up to my 4runners or extended cab trucks as the light that mounts in the center isnt much use for the driver. I run the wire to the top left corner for electrical. I show this in my 88 Runner build.
I got a dome light out of a Standard cab out of a salvage with the same interior color as my wife truck and mounted it in to where your mirror is. I just drilled a small hole to run wires along the windshield to the driverswindshield post and poped off the trim.
There is 2 wires that run along the post that I tapped into and soldered and taped up. Get the plug to the mirror and about 3 feet of the wire out of the donor truck and screw in. Easy and cheap upgrade. The dome ligh on a extended cab and 4Runner is behind you and doesnt light the floorboard up and that is where I am usually trying to find my things.
Front and Rear Dome. Not the best picture, but gives you the idea. Door and On Light work.
Where I tapped into wires.
Old Nov 28, 2013 | 04:01 AM
  #462
JohnnyCanuck's Avatar
Nice, I especially like the light, my interior light sucks. I'm finally near a huge pick & pull which has a couple of nice sr5 4runners that I can plunder.
Old Dec 1, 2013 | 08:30 PM
  #463
412eRunner's Avatar
So i found this at the local pick a part it was on a 87 4runner , damn thing was heavy it looks like in the middle theres a winch mount .What yall think??? has anyone seen this bumper before?
Old Dec 1, 2013 | 08:39 PM
  #464
boxer.fan's Avatar
Score! How much?
Old Dec 4, 2013 | 03:59 PM
  #465
bone collector's Avatar
Score of the Century!!!! 60 dollars!!!! and yes that includes the crossover pipe....
Old Dec 4, 2013 | 04:43 PM
  #466
wow, what a steal, lucky duck.
Old Dec 4, 2013 | 04:49 PM
  #467
it wasn't from a junkyard, but yes, very lucky!!
Old Dec 5, 2013 | 08:05 PM
  #468
412eRunner's Avatar
$60 any one seen it before
Old Dec 5, 2013 | 09:39 PM
  #469
julsruls's Avatar
this cool thread. Most of junkyards around here wont let you browse which sucks cause sometimes you don't know what you want until you see it.
I have a 94 4runner that is just sitting in my driveway that im gonna steal a whole bunch of stuff from to put on my 85 4runner.
SOooo kind of like cheap junkyard mods.
Ill post as I do them.
Old Dec 10, 2013 | 08:50 PM
  #470
Giri's Avatar
Iv got an 88' Runner that i put the second gen center console in " 8 bucks" alot deeper and perfect elbow resting level, front screws match perfect and i just added one extra hole in the rear that matched the 1st gen bracket and glued some pennies over the old holes. the rear window button and coin slot on the front swap right over too
Old Dec 13, 2013 | 03:11 PM
  #471
Finally4running's Avatar
Originally Posted by LADave
'Yota trucks are very scarce in self-service yards around LA. Rumor has it that they are quickly bought up and shipped to the Middle East. Apparently once you have your Kalashnikov, a 'Yota is next on your fashion accessory must-have list.
Ive heard the same around here, as well as to south america and such.
Old Dec 13, 2013 | 05:46 PM
  #472
ToyoTech559's Avatar
Could you post up pix of it installed. I wanna see how and where the cross over goes. I got mine used and it came with cross over but I don't like how it's routed and wanna see if yours is done better
Old Dec 13, 2013 | 07:52 PM
  #473
RAD4Runner's Avatar
Yes, no better match...
Exactamente, señor
LOL!
Old Dec 14, 2013 | 01:02 PM
  #474
I will do that when I get them installed. I plan on doing it over Christmas break. To be honest, the crossover looks like it is made from a muffle shop, not the piece that came with the headers. When I saw this set installed on the other truck, Im pretty sure the crossover was tucked close to the transfer case. nicely tucked away too. I will be sure to post pictures when I do it
Old Sep 21, 2014 | 04:50 AM
  #475
JeremyW94's Avatar
Bump.........
Old Nov 25, 2014 | 08:31 PM
  #476
zader's Avatar
Best jy mod ive had is a 8" "1ton" rear axle 2wd ive put on my 86 2wd, got the fender decals too lol. soon to get a supra lsd rear third. And I found that a 2010 tacoma center console fits nicly between the bucket sr5's. Sorry no pics yet. Nice thread guys
Old Nov 25, 2014 | 10:38 PM
  #477
Terrys87's Avatar
My 87 2 wheel drive came with the 4 speed transmission. I bought an 83 Celica with the 5 speed transmission and it was a direct bolt in with no modifications needed. I also used some Ford Ranger factory rims on it with no modifications needed on it as well. A couple of two wheel drive junk yard mods I know of.
Old Nov 26, 2014 | 03:43 PM
  #478
peabody's Avatar
Nissan hardbody tow hooks, re-punched once on each. Cheap. More mods to come.
Old Dec 5, 2014 | 09:08 AM
  #479
RAD4Runner's Avatar
Not exactly a mod, but a smartphone or mp3 player of certain dimension would pop right in between dash and ashtray.
Here, I have the iPod Touch in rubberized case. Make sure it pops in place not just lay there., else you lose it when you make a sharp turn. Rubberized case helps.
Old Dec 5, 2014 | 09:13 AM
  #480
jennygirl's Avatar
Great idea. I knew that thing might actually have a use.
