Best Junkyard Mods
Old Dec 5, 2014 | 10:17 AM
  #481
Odin's Avatar
Originally Posted by Ron Helmuth
Crown Victoria horns or better.
Don't recall how your horns are but us 3rd gens have wimpy beep beep Road Runner horns.
I found a newly wrecked Crown Vic and the horns are reasonably better. PIAMM is the brand name.
Good idea
My 91 horn is pretty weak, it dang near sounds as wimpy as my motorcycles horn.
Old Dec 5, 2014 | 10:44 AM
  #482
RBX's Avatar
RBX
^^^ Or
4 Note Cadillac Horns, thems be loud!!
Old Dec 5, 2014 | 01:40 PM
  #483
Odin's Avatar
Originally Posted by RBX
^^^ Or
What year and style has those?
Old Dec 5, 2014 | 02:12 PM
  #484
RBX's Avatar
RBX
Iirc caddies up to late 80's and Buick road master from 90's.
Old Dec 6, 2014 | 02:51 AM
  #485
jennygirl's Avatar
I like my little weeper horn. Weep weep! So non-confrontational, but still enough to get attention.. Just does it without inciting rage
Old Dec 6, 2014 | 03:16 AM
  #486
Odin's Avatar
Jenny Jenny Jenny you're such a girl
It's more about making sure you get someone's attention. All the loud music, GPS systems, texting, talking on the phone, and just plain old bad driving going on these days is ridiculous. (I'm not against loud music while driving but some people just can't seem to do it correctly)
Old Dec 6, 2014 | 05:30 AM
  #487
Badger62811's Avatar
When I drive like --> but my horn says --> people are like -->
Old Dec 6, 2014 | 05:39 AM
  #488
rworegon's Avatar
^^ Good one Badger.
Old Dec 7, 2014 | 01:55 PM
  #489
Odin's Avatar
Old Dec 7, 2014 | 04:40 PM
  #490
zombie_stomp's Avatar
I got a pair of decent bucket seats out of a '95 4runner for my '82 longbed 4x4.
The rear brackets needed new holes about 3/4" further back, and the inner front mount needs to come down about a half inch, but otherwise they almost fit perfectly. The rear brackets I'm going to modify to sit back lower in the rear too.
The seat bottoms unbolt from the frame making it possible to run two passenger side seat bottoms, which are always less worn. I've swapped the passenger side to the drivers side for now.
I'm going to eventually upholster these grey seats to blue to match my interior and dye the plastic trim parts blue from grey as well. The pair only cost about $70.00 and the truck is so much more of a pleasure to drive now that the seats aren't killing my back, I should have done this with my '83 right off the bat!
Old Dec 9, 2014 | 05:26 PM
  #491
RoadRunner42's Avatar
Dont know if its been posted but VW Passat cupholders under the radio bezzel work AMAZING.
Old Dec 9, 2014 | 05:44 PM
  #492
HotNotch's Avatar
Can you add pics? What year passat should I look for
Old Dec 9, 2014 | 05:58 PM
  #493
Saw it on YotaTech along time ago. Works awesome!
https://www.yotatech.com/forums/f123/cup-holders-first-gen-4runner-second-gen-trucks-260137/
Old Dec 9, 2014 | 06:20 PM
  #494
Crapple21's Avatar
I'm glad that people are using this. It's probably the best thing interior wise I've done to my 4runner. I use it almost everyday
Old Dec 9, 2014 | 06:24 PM
  #495
It's a great idea!! I used it but had to remove it for the time being. I used some gorilla glue so it stick to the bottom of the bezel. Worked like a charm.
Old Dec 10, 2014 | 06:40 PM
  #496
kornhuskerwizard's Avatar
Early 90s late 80s gm trucks had a under hood retractable light that stretches out all the way to the rear of the vehicle.I always grab these at the boneyard.great upgrade.
Old Dec 10, 2014 | 08:04 PM
  #497
Haven't installed it yet but grabbed a fusebox out a 1998 Cherokee to use as an external fusebox/relay holder. BleepinJeep has a video on YouTube.
Old Dec 17, 2014 | 09:42 PM
  #498
Dale Johnston's Avatar
From: Strafford Missouri, right outside of Springfield
This came from a friends garage rather than my local PickNPull, but I just put the chrome rear bumper from a Ford Explorer on my 94 truck. Once I trimmed some excess plastic shrouds off it fit great. The brackets were the same spacing but the wrong bolt holes, most of you guys could probably drill new ones but I had to just weld mine because I raised my bumper to match the body lift on my 2wd. The best part is that it is solid and i no longer have to worry about the bumper corners folding into my bed corners!
Old Dec 18, 2014 | 05:01 AM
  #499
RBX's Avatar
RBX
I don't see any pics!
What year Exploder?
Old Dec 18, 2014 | 05:50 AM
  #500
reallifedog's Avatar
Im also interested in this here mod
