Best Junkyard Mods
Old Apr 26, 2012 | 10:09 AM
  #321
technojunkie's Avatar
I visited the local PullnPay a couple weeks ago:
'93 runner buckets $20 each
seatbelt buckles $5 each
digital clock $5
A/C switch $5 (didn't need it, but the original from the 'yota stealer was $60 now I have a spare)
Glove Box+speaker housing $10
Probably gonna go back for an instrument cluster ($20) Mine has a cracked lens
Having a much nicer interior: priceless.
Old May 1, 2012 | 07:20 AM
  #322
Jkelley429's Avatar
does anyone know which thread on here has a write up of how to jb weld the passages on the caddy compressor? i remember seeing it before, but i cant find it.
Old May 1, 2012 | 10:30 AM
  #323
3YLSYKR's Avatar
Those vids of the scion and the truck are loud. I don't want that loud lol. I just went with two twin red horns from sickspeed that will look good behind the grill.
Old May 1, 2012 | 03:28 PM
  #324
ultimase's Avatar
http://robinhood4x4.com/compressors.htm
Old May 2, 2012 | 01:38 AM
  #325
LADave's Avatar
'Yota trucks are very scarce in self-service yards around LA. Rumor has it that they are quickly bought up and shipped to the Middle East. Apparently once you have your Kalashnikov, a 'Yota is next on your fashion accessory must-have list.
Old May 2, 2012 | 02:58 AM
  #326
RAD4Runner's Avatar
[QUOTE=se7enine;51906281]Got these 3000GT seats and a momo steering wheel for under $70
Cool! Would like to have sportier (not showy, just firm, good support) seats ike those! Have you checked if they readily fit first gens?
TIA
Old May 3, 2012 | 06:36 PM
  #327
Guerrero_93's Avatar
are those horns plug and play?
Old May 3, 2012 | 07:22 PM
  #328
worshipmentor's Avatar
Funny you say that Dave cuz I live in Mississippi and most of the 4runners I find for sale are in LA
Old May 3, 2012 | 08:15 PM
  #329
Grego92's Avatar
Do you guys mean Louisiana or Los Angeles???? If Los Angeles....
Good amount of 2nd gen 4runners in Los Angeles, but like Dave said not pickup trucks. I've seen many late 70's to 88' but rarely 89-95. The two I've seen were in serious wrecks with major frame damage but at least the interior door panels were in great shape and that's what I needed.
Old May 3, 2012 | 10:14 PM
  #330
Stuwy123's Avatar
Bahaha, Toyota's are sold around the world. They rock hilux's over there. Not north american toyotas.
The toyota's in LA usually end in mexico. Or china for scrap steel.
Old May 6, 2012 | 02:16 PM
  #331
2big4arunner's Avatar
K. A small update on the suspension coil upgrade. As luck would have it while I was procrastinating about putting in the coils on the rear. I found out that all 4 of my shocks were gone. After looking around I got a set if bilstein shocks for all 4 corners for 25 bucks after tax. Yummy days
Old May 12, 2012 | 08:11 PM
  #332
rockroller's Avatar
humm good posts
been wanting to change my read springs on my 93 t100 reg cab 4x4 long box
will the chev 63 springs fit? also will they give the rear a bit of lift?
i drive also of back roads and my suspention suck also the drink holders are in the worth spot ever coffeee all over everything
Old May 12, 2012 | 08:15 PM
  #333
BoredOutnJackdUp's Avatar
Take a peak at this rockroller
http://www.pirate4x4.com/forum/showthread.php?t=20665
Old May 12, 2012 | 09:11 PM
  #334
rockroller's Avatar
hey thats good
thanks for the info on this
im runing new ranco shocks in the rear so im guessing it will work out great
know any more good info on the t100 cheap wise im on a red neck buget
Old May 13, 2012 | 03:05 PM
  #335
Weld the rear end lol
Old May 13, 2012 | 07:47 PM
  #336
Blackulua's Avatar
82 supra AFM,r151f tranny,v-6 rear diffs,85 front axle etc....
Old May 14, 2012 | 08:37 AM
  #337
Stuwy123's Avatar
Swing out spare tire carrier:
Old May 14, 2012 | 10:19 AM
  #338
wii_tarded's Avatar
^^^what did you do to brace it on the inside when installing?
Old May 14, 2012 | 11:14 AM
  #339
Stuwy123's Avatar
I used the inner bracing bracket that came from the 4Runner.
I had to cut it down quite a bit because the corner on the pickup is completely different than the 4Runner (behind the outer sheetmetal).
Old May 14, 2012 | 11:27 AM
  #340
wii_tarded's Avatar
For all you guys, how hard is it to brace the factory carrier on a T4R that didn't come with one? I don't have a welder at easy disposal, and would like to be able to bolt it in... I just don't know what and where it needs it.
