Best Junkyard Mods
Old Feb 4, 2013 | 05:23 PM
  #361
BamaYota1's Avatar
I got the speaker enclosures from a 4runner, carpet for my truck, and door sills for $11.00.
Speaker enclosures are still one of my favorite mods.
Old Feb 12, 2013 | 11:29 PM
  #362
foppert's Avatar
Found one of the Montero gauge mounts, but the compass and inclinometer were destroyed. Still took it and mounted tach and volt gauge; because every time i find an sr5 gauge cluster its been torn to pieces. My local pick n pulls people show up and tear interiors to shreds looking fors speaker parts to sell out of their trunks outside. Its pretty sad.
Found a 1980's toyota racing jacket at a flea market though, almost as cool
http://www.ebay.com/itm/TOYOTA-LINE-...item19d8ab04ab
subscribed....
Old Feb 13, 2013 | 08:55 AM
  #363
Outsane's Avatar
I want that jacket... but too much $$$$
Old Feb 27, 2013 | 06:02 AM
  #364
liveoffroad's Avatar
Originally Posted by Richard
2wd u-bolts and plates for a cheap u-bolt flip
thats a great idea! can't believe how much u-bolts cost new
Old Mar 4, 2013 | 06:01 PM
  #365
plocc31726's Avatar
Just scored sr5 instrument gauge cluster for my 87 4runner at the u pull and pay, also front seats, rear seats and roll bar pad, trim pieces for the removable top all for $140.00
Old Mar 5, 2013 | 06:43 PM
  #366
stanprophet's Avatar
Tagging this for a junk yard run Thursday!
Old Mar 5, 2013 | 07:11 PM
  #367
'85 Yota's Avatar
Found some decent seat covers, $6. Bunch of 4 gauge stereo wiring to get enough for the big 3 upgrade, and a clock from an sr5.
Old Apr 24, 2013 | 08:16 PM
  #368
'85 Yota's Avatar
Found some Hella Ecode h4s the other day. Stashed them somewhere because I didn't have moneys, came back today and got them today for $22!
Old May 1, 2013 | 07:52 AM
  #369
The Other Guy's Avatar
This is more of a junk mod than a junkyard mod. This was actually the PO's and I almost threw it out before realizing what it was used for. You just take a roll of masking tape and lay it on the floor in the center in front of the seat (if you have bench seats) and then insert drink, instant drink holder and much better than the one in the dash.
Old May 1, 2013 | 08:25 AM
  #370
'85 Yota's Avatar
Corner bulbs from a Honda Accord for the blinker into corner light mod!
Old May 1, 2013 | 09:29 AM
  #371
RAD4Runner's Avatar
Nice idea. I added a fender mounted turn signal but I want more visibility. Did you have to change the connector? Bulb mount? Did you use just the bulb or did you actually take the connector from the Accord and mounted in in place of stock?
Old May 1, 2013 | 08:49 PM
  #372
maco35's Avatar
What honda year? and any pics. of mod.
Old May 1, 2013 | 09:01 PM
  #373
'85 Yota's Avatar
I think it was an 86? theres a thread on here about it. search for it. but i used the connector from the little marker lights off the accord. then drilled a hole in the corner light. there is already two little holes that arent cut out. i drilled the top one out and wedged the accord bulb in there. then just spliced my old turn signal wires to the bulb. the blinkers blink twice as fast because the bulb is smaller. but you could just add a couple more lights.
Old May 1, 2013 | 09:32 PM
  #374
Vang530's Avatar
WTF!! how come no one told me of this?!? What years should I look out for?
You just saved me some $$$ I really appreciate it
Old May 2, 2013 | 03:50 AM
  #375
irab88's Avatar
84-95. the suspension didn't change much over the years.
Old May 6, 2013 | 09:01 PM
  #376
Vang530's Avatar
I just looked at mine. I don't think it will work because of the stock shock mounts are way different...needs modifying
Old May 7, 2013 | 05:03 AM
  #377
irab88's Avatar
yeah, the shocks get mounted differently up top, so a bit more work needed. but still an easy, cheap flip-kit!
Old May 10, 2013 | 08:00 PM
  #378
I had that on my 1980 p/u , only works with pre IFS rear , I don't know the axle tube diameter newer model 2wd rears
Old May 12, 2013 | 03:41 PM
  #379
Teuf's Avatar
Are shocks affective at such an angle?
Old May 13, 2013 | 03:47 AM
  #380
irab88's Avatar
at that angle, only 1/2 as effective as straight up-down. the more vertical you mount them, the more effective they become
