Best Junkyard Mods
#362
Found one of the Montero gauge mounts, but the compass and inclinometer were destroyed. Still took it and mounted tach and volt gauge; because every time i find an sr5 gauge cluster its been torn to pieces. My local pick n pulls people show up and tear interiors to shreds looking fors speaker parts to sell out of their trunks outside. Its pretty sad.
Found a 1980's toyota racing jacket at a flea market though, almost as cool
http://www.ebay.com/itm/TOYOTA-LINE-...item19d8ab04ab
subscribed....
subscribed....
#369
This is more of a junk mod than a junkyard mod. This was actually the PO's and I almost threw it out before realizing what it was used for. You just take a roll of masking tape and lay it on the floor in the center in front of the seat (if you have bench seats) and then insert drink, instant drink holder and much better than the one in the dash.
#371
Nice idea. I added a fender mounted turn signal but I want more visibility. Did you have to change the connector? Bulb mount? Did you use just the bulb or did you actually take the connector from the Accord and mounted in in place of stock?
#373
I think it was an 86? theres a thread on here about it. search for it. but i used the connector from the little marker lights off the accord. then drilled a hole in the corner light. there is already two little holes that arent cut out. i drilled the top one out and wedged the accord bulb in there. then just spliced my old turn signal wires to the bulb. the blinkers blink twice as fast because the bulb is smaller. but you could just add a couple more lights.
#374
#376
#378
