BEGINNER'S 22re Timing Chain Failure / replacement / head gasket replacement
Old Mar 26, 2011 | 08:57 PM
  #141
8 T 8's Avatar
Totally dug your posts and read it start-to-finish. Did this a couple years ago on my 2WD. Didn't do as much cosmetic detailing but OCD'd on CLEANING and got the engine compartment back to new condition on an 88 while re-doing practically EVERYTHING under the hood. And all to have a reliable rig! It feels good and I was also an amateur mechanic. I mean, I was ASI certified in 1990-Advanced Security Institute! LOL!
And I can totally relate to having to drop the steering components just to change an oil pan.
Old Mar 28, 2011 | 11:38 AM
  #142
veeyota's Avatar
what could be the problem??? i just got my timing chain fixed.. but now i think its leaking oil from the timing cover at the bottom..?? could it be that the cover is not sealed good enough??? leaks from where the cover meets the oil pan?and i think its leaking from one of the pulley too?? any help would help.. thanks.
Old Mar 28, 2011 | 11:39 AM
  #143
Lumpy's Avatar
Could be the cover, oil pump, or pan...
Old Mar 28, 2011 | 11:44 AM
  #144
veeyota's Avatar
f***!! that means that gonna have to take it all off again right??
Old Mar 28, 2011 | 12:09 PM
  #145
Lumpy's Avatar
Clean it all off really well and find out for certain where it's coming from.
Just might have to pull the pan and reseal it.
Old Mar 28, 2011 | 12:43 PM
  #146
irab88's Avatar
i should probably subscribe...
(i do have it bookmarked, though)
Old Mar 28, 2011 | 02:45 PM
  #147
92 TOY's Avatar
there's a quiz april 16th.....just sayin'
Old Mar 28, 2011 | 02:58 PM
  #148
irab88's Avatar
dam... gotta study...
Old Mar 28, 2011 | 05:18 PM
  #149
toyospearo's Avatar
GREAT THREAD!
I am almost done with a complete engine rebuild and I am painting a few things...timing cover, water pump etc. I am wonder how the BBQ paint on the manifold held up??? My header looks like hell and I thought I might paint it.
Old Mar 28, 2011 | 05:40 PM
  #150
92 TOY's Avatar
thanks man....that means alot coming from you.
BBQ paint was only used on exhaust manifold......after a few minutes of it smoking (the can warns you, but i only read that AFTER it was smoking) and a few weeks of a stank, it went to black....a pretty good looking, clean black and has stayed that way.
Old Mar 31, 2011 | 12:11 PM
  #151
SlightlyWhat's Avatar
Question.
Is there a gasket that's suppose to fit here with the cooling pipe? I havea gasket that I haven't used yet and dunno where it's suppose to go. Not only that but I didn't see a gasket come off when I pulled my lower intake off.
Old Mar 31, 2011 | 12:12 PM
  #152
yotarob2005's Avatar
Yes there should be a gasket. I imagine that without one it would leak like pig.
Old Mar 31, 2011 | 12:43 PM
  #153
Lumpy's Avatar
Actually that takes an 0 ring...
Old Mar 31, 2011 | 12:53 PM
  #154
Really? My memory must be slipping with age
Old Mar 31, 2011 | 12:54 PM
  #155
92 TOY's Avatar
yep...O-ring....yep....didn't have one....YEP....used lotsa RTV there
Old Mar 31, 2011 | 12:55 PM
  #156
anyone have a picture?
O.o...hope it's available at autozone...
  #157
what color?
Old Mar 31, 2011 | 12:57 PM
  #158
Originally Posted by SlightlyWhat
what color?
Second thought on that RTV because that pipe is hard to put back in place. It's unaligned so the bolts that need to go in wont go in straight and I don't have the fuel rail off or vice grips that will fit...
Old Mar 31, 2011 | 01:29 PM
  #159
92 TOY's Avatar
yep....that's the problem with that connection and the problem i exactly had. the vice grips were the only way i could get that aligned ......i would recommend getting some versus cross-threading.
Old Apr 1, 2011 | 05:00 AM
  #160
Lumpy's Avatar
Keep everything loose then put the pipe in, it'll go. I found an O-Ring at the local auto parts store. I don't have a size for ya thought...
