Anyone have their ECU rebuilt?
Old Nov 6, 2015 | 01:29 AM
mtrdrms's Avatar
I believe I have narrowed down my code 52 to the ecu. I am hesitant to buy a used one and wanted to see if anyone had any luck with sending theirs out to be rebuilt? If so, who did you send it to?
Thanks.
Old Nov 6, 2015 | 03:50 AM
voiddweller's Avatar
Personally I'd buy a used factory ecu before a reman job. I've had a couple reman ecus go bad
Old Nov 6, 2015 | 04:21 AM
kcaudill's Avatar
I would open it up and look for corrosion, If you have some, used tv tuner spray, clean it all up then look for broken solder joints and repair those. There is not much in these dinosaurs. I had same problem, found allot corrosion and broken solder joints, repaired myself.
Disclaimer
My truck would not run at all, i used a friend ecu to confirm mine was bad before starting such a task, I had nothing to lose and everything to gain.
Old Nov 6, 2015 | 08:57 AM
wyoming9's Avatar
Red face
I have had good luck with ECM Depot out of Texas .
I think @ $300.00 with a core
Good Warranty unless it gets water damage .
Old Nov 6, 2015 | 01:34 PM
mtrdrms's Avatar
Other than the case being corroded, I have no idea what to look for but it looks ok to me?
Old Nov 6, 2015 | 02:02 PM
What year/model truck?
Old Nov 6, 2015 | 04:08 PM
mtrdrms's Avatar
Sorry, 1993 sr5, auto. 4X4.
Old Nov 7, 2015 | 12:11 AM
Terrys87's Avatar
Other then a Turbo truck I have never seen a non turbo computer not fail unless it got wet. I would take my chance with a used one. I was unaware that you could get remanufactured computers but a truck I bought awhile back did have one in it that had a reman sticker on it.
Old Nov 7, 2015 | 03:31 PM
dzldust's Avatar
Mine looks the same inside but obviously has something wrong with it,put it I my buddy's truck and acts exactly like it does in mine.oh well
Old Nov 7, 2015 | 03:53 PM
mtrdrms's Avatar
What is your truck doing? Are you gonna get it rebuilt or get a used one?
Old Nov 7, 2015 | 04:02 PM
dzldust's Avatar
-Random miss
-Erratic CEL ( no pattern to blinks)
-Timing pulled when miss happens while watching with timing light
Took a buddies running 86 22re and swapped out plug wires,cap,distributer,AFM,TPS,coil/igniter.All one at a time and nothing changed until I swapped in his ecu,now with his ecu it runs great with all my original parts still in place .no stutter ,no cel.Now his runs like crap now with my ecu in his truck.ha ha
Old Nov 7, 2015 | 04:15 PM
Terrys87's Avatar
Sounds like you do have a bad computer. As far as Check Engine Light that comes on intermittently with no codes, in my past experience it is due to some vacuum leaks. I would replace the vacuum lines if they are old and brittle.
Old Nov 9, 2015 | 05:38 PM
dzldust's Avatar
runs great wit my buddys ecm,vacuum lines are all tight and pliable
Old Nov 10, 2015 | 07:18 AM
kcaudill's Avatar
Mine had allot of corrosion around the transistors attached to the housing and around the input pins going to the board.
Old Nov 10, 2015 | 07:36 AM
dzldust's Avatar
Mine looks like new inside but after cleaning contacts and looking closely at everything it still is acting up
Old Nov 10, 2015 | 02:03 PM
mtrdrms's Avatar
Thanks.
Well I put a remanufactured ecu in and the code 52 is still there. Bummed.
zombie_stomp
Jun 26, 2016 05:49 PM
Volnychev
Nov 6, 2015 07:05 AM
twasabug
Nov 5, 2015 11:56 PM
scott90
17
Oct 26, 2015 10:33 AM
Black306
Oct 19, 2015 02:19 AM
