anyone have/install REAR speakers on a 1st gen 4Runner?
Old 03-14-2005, 08:05 PM
Spark-e3's Avatar
Here's what worked for me. I used some 3/16" wood panel material and cut it to match the curve of the wheelwell on the bottom and cut it at the top flush with the bedrail. They are cut wide enough to fit a 6x9 into and I was able to use self tapping screws along the top and bottom edges to secure the panel to metal. I did all this over the plastic side panel covers which had already been cut for 6x9's. It's a very secure and quick way to attach a variety of speaker sizes just rear of the rollbar. Make a template out of cardboard to get idea where to make cut following curve of the bottom edge. The panels meets tight with the carpet so you have plenty to shoot screws into.
Good luck!!
Old 03-14-2005, 08:11 PM
bike4miles's Avatar
Originally Posted by dajabr
I had some boxes made, can talke them out for field parties...
That's a sweet setup. Not like anything I have seen before.
Old 03-14-2005, 08:24 PM
4Crawler's Avatar
The PO of my '85 installed some 6x9s in the rear panel:
I added the power inverter and fire extinguisher.
Old 03-14-2005, 08:29 PM
Your setup isn't too bad Roger but my wonderful red panels in the back are showing their old age and are cracking up from the prior owners abusing them. I had to pull out the passenger side one today and I'm trying to cut a sheet of metal to fit in it's place with the speaker behind it to stay out of the rain. Although I could go with marine speakers for when I put on the bikini top.
Old 02-11-2018, 05:37 PM
  #25
Robert Hernández's Avatar
Were can I get them
Originally Posted by Erich_870
Well, I'm embarassed to took so long to post this pic, but here it is :pat: this is the bracket to replace the stock ones in the rear panels of my 1st Gen.
i just got myself a 89 1st gen it was missing rear speakers I’ve been wondering how to mount them. Are they originally mounted like that? How can I get those bracket mounts?
Old 02-11-2018, 07:25 PM
  #26
Co_94_PU's Avatar
600xStereo 4runner rears and harness
Full harness and new(to me) 4runner powered rear speakers
These are 2nd gen 4runner rear speaker boxes with internal amplifier, the first gen are similar. As above they are factory mounted behind the panel near the rollbar on the little tabs.
The post you quoted are fabricated mounts for generic aftermarket speakers.
Old 02-12-2018, 06:17 PM
  #27
Nervo19's Avatar
There
were no rear speakers in my '89. I cut luan plywood and covered it in insulation and mounted 5 1/2" Infinity speakers behind the panel. There's a better explanation on my thread. I wanted the speakers to be hidden.
Old 02-12-2018, 10:02 PM
  #28
maco35's Avatar
Here is an idea on how to mount them with out cutting the plastic. http://www.toyota-4runner.org/classi...restore-5.html
Old 02-12-2018, 10:09 PM
  #29
Co_94_PU's Avatar
i didn't read all that, but visually "don't cut the plastic trim" springs to mind. Purists will happily trade you less than perfect trim you can destroy for good unmolested panels..
My 4runner had a large powered subwoofer box, removed by PO before sale (they left the "monster cable" power wire. So glad they didn't cut the panels.
Old 02-13-2018, 09:24 AM
  #30
Griswald's Avatar
Originally Posted by bike4miles
Yep, the reason I soundproofed everything. Now it sounds even better without any pannel vibration.
How did you soundproof it?
Turboz
10-09-2017 01:33 PM
b4wheeler
06-06-2017 08:00 AM
Charles4x4
06-05-2017 06:25 AM
Vagrant No2
05-22-2017 09:59 AM
atcfixer
04-02-2017 08:45 PM
Quick Reply: anyone have/install REAR speakers on a 1st gen 4Runner?
