Alternator Upgrade?
Old Mar 10, 2009 | 01:01 PM
xalier's Avatar
Alternator Upgrade?
I was curious if anyone knew of a junkyard or similar cheap upgrade for the alt. I have a 90p/u. Any info would be appreciated. I thought the 4runners might have more amps since they have more lights and electronics.
Old Mar 10, 2009 | 01:46 PM
Junkers88's Avatar
I remember seeing a thread on a Chevy alt upgrade although I can't seem to find it now.
Just wondering why you're looking to upgrade?
Old Mar 10, 2009 | 02:03 PM
OutlawMike's Avatar
Something over on Pirate:
http://www.pirate4x4.com/forum/showt...hlight=OOP%27S
Or, converting a Toyota to 90 amps:
http://www.4x4wire.com/toyota/tech/alternator/
Search my son, and you shall find more info than you can possibly absorb.
Old Mar 10, 2009 | 02:10 PM
OutlawMike's Avatar
Or, an MR2 Alternator from a boneyard, 100 amps:
http://www.off-road.com/trucks4x4/ar....jsp?id=186492
Old Mar 10, 2009 | 02:59 PM
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
There's also a few places that you can have your stock Toy alt re-wound. But I don't remember the names, or a price range, sorry.
Old Mar 10, 2009 | 03:39 PM
sas'd22re's Avatar
was thinking about doing something like this as well. i have a large stereo, am putting some rock lights underneath and am picking up a winch soon so could use some more amps. is there anything else that has to be upgraded to handle the higher amps or are you just good to go?
Old Mar 10, 2009 | 03:44 PM
Windsor's Avatar
https://www.yotatech.com/forums/f116...pgrade-162594/
Old Mar 10, 2009 | 03:49 PM
Thanx for the save Windsor!!!!!
Old Mar 10, 2009 | 04:01 PM
Windsor's Avatar
Welcome.
I have it bookmarked, I plan on using their services soon -- my junkyard alternator is in the garage waiting for me to box it up.
Old Mar 11, 2009 | 03:26 AM
TNRabbit's Avatar
Contact these guys:
Boyle Future Technology
12325 Locksley Lane
Auburn, CA 95602
Phone: 530-888-6290
more links:
https://www.yotatech.com/forums/f116/alt-swaps-93053/
https://www.yotatech.com/forums/f116...market-114474/
https://www.yotatech.com/forums/f116...attery-135096/
They can upgrade the stock wimpy 60 amp to 130 amp, 75 of which is available at idle! I paid $170.00 shipped both ways @ little over a year ago.
Old Mar 11, 2009 | 06:32 AM
khoopes's Avatar
power management
I just wanted to comment that I have recently purchased an aftermarket reman and a Toyota reman, and the Toyota reman was so much better workmanship its not even funny. I bought a new Toyota battery too for my pickup.
An option instead of trying to high horse the alternator is to minimize the power consumption. For instance, instead of using 130 watt incandescents, try using 35 watt HID's. Put some good capacitors on your sub amps to smooth out the current draw. Try a hydraulic winch instead of an electric one, they run cooler anyway. You can even replace your headlamps with HID's and get rid of 5 or 6 amps.
Even so, before you go buying a new alternator, do a DC current test if do not have an ammeter and see how much you are really using under these "severe" trail conditions.
Just a few thoughts! Then go by a high amp alternator if it makes you feel good!
Old Mar 11, 2009 | 08:25 AM
space-junk's Avatar
but what if you have all you lights on (i mean, like say, 10 add on lights) at the same time on the trail...
yea, power consumption should be watched closely and limited to an extent, but come on, really, 65 amps?? what was toyota thinking... get your stocker rewound... you will love never having to worry about it again...
Old Mar 12, 2009 | 03:51 AM
TNRabbit's Avatar
x2....
Old Mar 12, 2009 | 07:24 AM
DeathCougar's Avatar
I plan on getting mine rewound over the summer.
Talk to Taikowaza, we just installed a Boyle's rewound alt in his truck, and he has a lot of accessories.
Old Mar 20, 2009 | 10:17 PM
toyotanick's Avatar
my lights dim when the bass hits... i think i need one too.
Old Mar 20, 2009 | 10:54 PM
abecedarian's Avatar
now you got me thinkin; ...maybe I'll pull my a/c compressor out and put a big delco in its place... 2 alts anyone???
Old Jun 18, 2009 | 09:52 AM
xalier's Avatar
is it possible to run 2 alts?
Old Jun 18, 2009 | 10:53 AM
aviator's Avatar
Dual alts is possible if you don't have A/C (there is mod info some where around I've seen it, don't remember where) try welding websites... I think I saw one on one of them...maybe Linc-arc?... they also make a 200A alt that can be fitted...
other tricks you can do is switch all lighting to LEDs... almost 0 current draw with them and longer life too.
Old Jun 18, 2009 | 09:07 PM
geminiroq's Avatar
Where is a good place to get these LED's?
Also...is the MR2 alternator a plug and play...and from what years?
Optioins are good when it comes to building these rigs.
Thank you,
Old Jun 19, 2009 | 08:12 PM
geminiroq's Avatar
bump...this is a good thread.
