adding seafoam to intake
Old Jan 24, 2010 | 02:43 PM
Localmotionsc's Avatar
I've done LOTS of searching and havent been able to find an answer for this so i'm starting a new thread.
I have a 1989 toyota pickup with a 22re in it, I bought some seafoam added half a tank to the gas and i want to add the rest to the intake.
I searched and found that most people suck it into the intake through the pcv valve hose or the brake booster hose. I have no knowledge of the brake booster, or its location so i decided i would try the pcv valve. After finally finding it i warmed up my truck and was about to add it to the intake but when i pulled the pcv valve the truck died.
My question is what am i doing wrong? and second which end of the pcv valve hose to i pull off the end connected to the valve cover or the end that connects to the intake?
if anyone has a picture it would be much appreciated. I hav
Old Jan 24, 2010 | 02:57 PM
Junkers88's Avatar
When you pulled the hose off of the PCV valve you created a vacuum leak and the engine died due to that. The best way is through the brake booster hose.
On the fire wall right in front of the driver is the brake assembly and booster (big black round thing) on the front of that is a hose. Start the truck and pull that hose and put your finger on it to keep vacuum. What I did at this point was to tilt the bottle of SF and ease my finger off the end of the hose until there was an opening. Pour the SF into that opening SLOWLY. You'll need someone to keep the rpms of the engine up while you do this or it will die. Once that half bottle of SF is in there put the hose back on the booster and shut the truck off. Let it sit (I think it's 20 minutes on the instructions on the bottle) and then fire it up.
Be prepared for lots and lots of smoke. By lots and lots I mean enough to kill insects for several blocks.
Old Jan 24, 2010 | 03:01 PM
thank you sooo much i have been looking for an answer forever this is exactly what i was looking for.
Old Jan 24, 2010 | 03:02 PM
toyotabull's Avatar
https://www.yotatech.com/forums/f116...-truth-160614/
read this and it will answer alot of questions about seafoam and welcome to yotatech
Old Jan 24, 2010 | 03:07 PM
4Crawler's Avatar
I used the hose that runs to the charcoal cannister when I did my '85. It is easy hose to get to, it is long and a smaller dia. so it is easier to control the flow of the cleaner into it.
Old Jan 24, 2010 | 03:09 PM
iamsuperbleeder's Avatar
lol
so true...
Old Jan 24, 2010 | 04:20 PM
Junkers88's Avatar
Originally Posted by iamsuperbleeder
lol
so true...
Indeed! I did my first shot of this two years ago and we had almost an entire block of white smoke. Good thing was there were no skeeters for a week after that. Bad thing was the fire department arrived due to someone calling in a fire........ Damn that was a LOT of smoke.
Old Jan 24, 2010 | 11:37 PM
Thanks so much guys, i did it through my brake booster line today. It worked perfectly, and my idle is smoother than ever, now i just need to adjust those valves...
Old Jan 25, 2010 | 12:03 AM
abecedarian's Avatar
Call me weird (why not? I do. )
I'd rather spray a cleaner up through the throat of the throttle body and let it set so it can soak in and loosen things up instead of putting something in through a vacuum line which gets sucked in and burned off and hopefully drags some stuff off the runners with it.
And for the record, I've done Seafoam through a vacuum hose and didn't "Sea" any change unless you want to call the smoke "foam"- was a waste of 10 dollars, in my opinion. Sprayed some 5 dollar generic TB cleaner up through the TB and let it set before starting the engine it ran a lot smoother, once it started.
Old Jan 25, 2010 | 06:04 AM
Junkers88's Avatar
So you just soaked the inside of the intake plenum and let it sit for a while?
Old Jan 25, 2010 | 10:09 PM
Sprayed it a few times, let it soak a few minutes, sprayed again, let it soak, started the beast and 'blew' out the gunk until the exhaust wasn't billowing, then repeated a couple more times until the can was empty. You just don't want to spray too much in at time, between starts, 'cause you don't want it sitting on the rings too long (there's always an open intake valve).
...And if I'd have had one, I would've bottle brushed it too.
Old Jan 25, 2010 | 11:13 PM
91muddog's Avatar
i was able to do it on the pvc valve hose on both a 22re and 3vze using my thumb to partially cover the hose while pouring the seafoam in, kept just enough vacuum to run the engines
Old Jan 25, 2010 | 11:17 PM
forbiddenera's Avatar
Hm.. I just took the brake booster off and stuck it in the can. Worked fine, truck didn't stall until a lot got in the engine which was the point wasn't it? Let it sit start it up and watch it smoke.
Old Jan 26, 2010 | 12:34 AM
Would you shampoo your hair while the shower head is still spraying water on it, rinsing the shampoo off? ... or would you apply the shampoo first, then rinse it off later?
Old Jan 26, 2010 | 05:03 AM
Junkers88's Avatar
I dont' have any hair......
Old Jan 26, 2010 | 07:43 AM
Toyoda22's Avatar
^^^^ hahaha
Seems like that bottle of TB cleaner is a good way to fry your oxygen sensors by blowing all that gunk through it
Old Jan 26, 2010 | 08:36 AM
QuickPaws's Avatar
I'm sorry. I had to lulz.
Back to your regularly scheduled threading. O.o
Old Jan 26, 2010 | 08:38 AM
DupermanDave's Avatar
Originally Posted by Toyoda22
^^^^ hahaha
At least the throttle body will be clean.
urabus
Nov 10, 2015 07:38 PM
93RedKrawler
Sep 25, 2015 04:03 AM
Anthony Lee Mathis
Sep 15, 2015 07:22 AM
sanctfy
Sep 13, 2015 06:33 PM
Boomer8404
Sep 10, 2015 09:01 AM
