93 4Runner Rear Brake Drums and Shoes - Adjuster and One Drum Not Coming Off
Old Oct 15, 2020 | 12:13 PM
Co_94_PU's Avatar
Originally Posted by surf4life
Yes the spec is I think 4mm - 8mm. I will double check the FSM. I will look at the inspection ports today. I'm curious what the spec is for clearance between the shoe and drum or if i can even see that from the inspection port?
0.3mm and yea you can
Old Oct 15, 2020 | 12:26 PM
Mr. Z.'s Avatar
Originally Posted by Co_94_PU
Got a good laugh here, "rotate the wheel so you can see each brake shoe", if my brake move when I spin the wheel how do they stop the wheel?! Can't picture what you tried to describe.
It was distracted and misspoke, the spec they give is iirc for pad thickness.
Regardless yes there are rubber plugged inspection holes on the backing plate. This gives you access to the pad Assembly and can apply a little force to the backing plate the pads are attached to.
Wow! Not sure what I was thinking...
I should really reread what I type before sending it on...
My apologies!
Old Oct 15, 2020 | 12:49 PM
surf4life's Avatar
My apologies!
No worries, everything is working out and hopefully this thread helps another in the future. Drum brakes are a damn nightmare!
SodiumFlouride
Feb 18, 2018 12:13 PM
billkmiami
7
Sep 18, 2016 12:32 PM
2002 taco
10
Feb 18, 2014 05:40 PM
BajaRunner
Jul 11, 2010 12:43 PM
Cwaters1184
Mar 31, 2009 09:21 AM
