92 TOY's 22re / crapped out / gotta start somewhere / thread
Old Nov 4, 2009 | 02:35 AM
  #441
92 TOY's Avatar
Originally Posted by ayoung101
been a week since the last post. any update?
How many excuses would you like?
Biggest would be no $$$$ to buy parts.
2nd would be I've had almost no time to do anything.Work has been exhausting me.
For now, I am just lurking and reading up on this process and trying to scheme how to get some extra $$$$$.....
Planning on taking my game into the basement and cleaning the head and valves as best I can with what I have.
I do have a question. The one spark plug was not threaded all the way in even though it felt like it was, can I re-tap that? What size? It's the same hole that the ceramic broke on the plug when I was taking the old plug out. Ran well as-is, so it's not like it's not getting the proper spark, but I just want to do this while I have the head out.
Old Nov 4, 2009 | 03:53 AM
  #442
flyingbrass's Avatar
Use a thread chaser, not a tap. Something like this. I think our plugs are 14mm.
Old Nov 4, 2009 | 04:04 AM
  #443
92 TOY's Avatar
thanks a zillion............!!!!
same kinda question.......as far as the head bolts go, I know enough that I will use new ones, but on about half the holes, the were very wet with oil and the others were dried on / caked on mess of oil or whatever......I assume that there must be a good reason why there is oil there right??? But anyway, as a way to clean them out properly, so I use the same kind of "tap'' or something like that to get all the debris out of the holes?? My concern is not being able to get the bolts torqued down properly due to debris or oil.
tanx!
Old Nov 4, 2009 | 04:05 AM
  #444
92 TOY's Avatar
this is what i am talking about
[IMG][/IMG]
Old Nov 4, 2009 | 04:48 AM
  #445
Be sure to clean the head bolt holes out well. You could buy a chaser or make one by cutting a few grooves in an old head bolt (which is probably what I'll do). The grooves provide a place for crud to collect. The pic of the plug chaser I linked above shows what I mean.
A few of my bolts were bathed in oil, while the rest were dry. The tighest one for me was 2nd back from the front on the driver's side. It was dry but also slightly rusted.
Old Nov 4, 2009 | 04:55 AM
  #446
92 TOY's Avatar
as you see in the pic, I had the same problem bolt. I'm going to assume there should be oil in there since of the several pics I've seen they all seem that way.
yeah, im gonna be looing for a tap that has notches in it to puke the oil and crud up and out.
Old Nov 4, 2009 | 05:05 AM
  #447
Lumpy's Avatar
I think I'd use the head bolt trick instead of buying another tool that you'll only use once (hopefully). Take an old head bold and cut slices out of it and use that to chase the threads.
Make sure you reseat the valves. The valve lapping toll is cheap and the goop is not expensive either.
Old Nov 4, 2009 | 05:16 AM
  #448
92 TOY's Avatar
OK, like I said, questions, I got a million of them.
What would I cut a bolt with?
What's that tube of stuff for? Cleaning the valves? I want to see what I get off using SEAFOAM and a scotchbrite and brake cleaner (besides a hazmat spill).
I'm leaving m headgasket on until I'm absolutely ready to put a new one on, figure it's providing some protection to the block right now, but I will scrape it clean.......can I shine the piston tops the same way as the valves??
Old Nov 4, 2009 | 05:17 AM
  #449
92 TOY's Avatar
oh yeah, what's that little tool for?
Old Nov 4, 2009 | 06:07 AM
  #450
Lumpy's Avatar
I'd scrape the old gasket off and clean the block real nice like and cover with a film of oil for now.
http://www.youtube.com/watch?v=fhXsH12Rg6s
Lapping the valves will keep the seats and the valves tight.
Old Nov 4, 2009 | 06:11 AM
  #451
92 TOY's Avatar
ok.
I'm not sure what I'm seeing done.
Looks like it's a suction cup???? I can't tell what the action is just above the view of the camera.
Old Nov 4, 2009 | 06:15 AM
  #452
Dremel tool or angle grinder with a cut-off disc.
  #453
Lumpy's Avatar
Just roll it back and forth in your hands. Like making a play-doe snake.
  #454
Lumpy's Avatar
here is another vid. Our valves come out the same way with the cone washer thingy.
http://www.youtube.com/watch?v=Ls7TCQ0U2Pg
Old Nov 4, 2009 | 06:28 AM
  #455
92 TOY's Avatar
I think I understand now.......because it grinds the valve against the head to make a mating surface right? the valves will rotate without an effort if i'm seeing that right.....the 2nd video made it better to understand.......
Old Nov 4, 2009 | 06:37 AM
  #456
Lumpy's Avatar
You said mating...
yep that be it. You will need to rent a valve removal tool though, they are a bit of a pain to get out. Or you may be able to make something like the kid made in the second vid.
Old Nov 4, 2009 | 06:43 AM
  #457
92 TOY's Avatar
Originally Posted by Lumpy
You said mating...
I meant to comment on that tool. That was a pretty slick trick with that window ut in there like that on copper pipe. That's a Maguiver(?spelling) trick. "necessity is the mother of invention"......is that the saying?
But that certainly looks like a basement project if I ever saw one.
Old Nov 4, 2009 | 06:45 AM
  #458
92 TOY's Avatar
[quote=Lumpy;51271486]You said mating...
quote]
And I guess that's a Beavis and Butthead reference....HEH-HEH , he said mating HEH HEH
Old Nov 4, 2009 | 07:11 AM
  #459
Lumpy's Avatar
I was hoping you'd catch it.
They'll clean up real nice like. The springs and the split cone washers are a real pain to work with. I had a buddy give me a hand with them.
Old Nov 4, 2009 | 07:18 AM
  #460
92 TOY's Avatar
i remember seeing a write-up where someone put the valves in a drill press and cleaned them up perfectly.
