92 TOY's 22re / crapped out / gotta start somewhere / thread
Old May 19, 2010 | 05:52 AM
  #2581
92 TOY's Avatar
Originally Posted by Lumpy
Thinking back I think I had to modify a paper gasket to fit just so. This could be the one I had to just make do with...
does it need a metallic one??????????????
same hot stuff as on the exhaust side of the head that i put a metallic one on.
Old May 19, 2010 | 05:53 AM
  #2582
92 TOY's Avatar
grrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr rrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr
Old May 19, 2010 | 05:54 AM
  #2583
Lumpy's Avatar
I believe I used a paper gasket...not real sure, that was a long time ago!!!
Old May 19, 2010 | 05:58 AM
  #2584
92 TOY's Avatar
going back down to lay out every gasket i have
Old May 19, 2010 | 06:08 AM
  #2585
92 TOY's Avatar
OCD can be quite helpful sometimes.
went to my box of parts from the tear-down and there it was laying there (the used one) and so that is what is going on there
Old May 19, 2010 | 06:09 AM
  #2586
92 TOY's Avatar
Ted also responded.....he's awesome.
he said, individually would be a tough one to find there and suggested getting some bulk high-temp gasket material and fabbing my own.
Old May 19, 2010 | 06:11 AM
  #2587
92 TOY's Avatar
gotta take a few minutes....gotta chill, was all p-o'd about that.
Old May 19, 2010 | 06:27 AM
  #2588
Lumpy's Avatar
Relax!!!
http://www.youtube.com/watch?v=lyl5DlrsU90
O ya I went there!!! I did!!! hahahahahaha
Old May 19, 2010 | 06:37 AM
  #2589
mel63's Avatar
I agree with Lumpy. Take a break, relax. Your doing a very nice job.
Mark
Old May 19, 2010 | 07:34 AM
  #2590
92 TOY's Avatar
thank you Mark.
OK...getting my butt kicked trying to line up with that REED valve.........grrrrrrrrrrrrrr
over an hour of struggling so far and still can't get it to line up.....grrrrrrrrrr
taking a much needed break.
PICS
No matter what amount of prying and wedging i do, i can't get the bolts to hit the holes......i have the valve itself loose and can pry around the tube only sooooo much.
Old May 19, 2010 | 07:35 AM
  #2591
92 TOY's Avatar
I am like RIGHT THERE and i still can get it to line up.
Old May 19, 2010 | 07:40 AM
  #2592
shawns88's Avatar
did you put it on the right way??? lol jk
i didnt have that much trouble with that tube wen i did my HG
try unbolting the mounts and then see if it will line up?
Old May 19, 2010 | 07:44 AM
  #2593
Lumpy's Avatar
Just gotta loosen some stuff up and wiggle about a bit and she'll go. Try standing on you left foot while balancing a cup of coffee on your right knee and (this is important) turn the screw with you left hand using a wrench made out of tin foil.
Old May 19, 2010 | 07:45 AM
  #2594
92 TOY's Avatar
what mounts? where the valve hooks onto the lower intake? already done.
will regroup and try again in a few.....maybe the toyota fairy put it back together for me while i'm sitting here......cuz actually, i went from about an inch and a half off to almost dead on...
Old May 19, 2010 | 07:48 AM
  #2595
Mazzola's Avatar
Just saying, you can probably use the wedding ring here too.
  #2596
92 TOY's Avatar
alerady done, but ya forgot about the smoke hanging out of the mouth and the camera in the other hand.....it looked like i was working on my truck with chop-sticks because i had the 4 foot breaker bar in one hand and a crow bar in the other and the a block of wood, a mirror (worthless) and vice grips.
it's not that i'm not trying hard enough.....might be i'm trying too hard.
"Luke , don't force it.........."
  #2597
92 TOY's Avatar
damn! if only i knew where it was.
Old May 19, 2010 | 07:50 AM
  #2598
shawns88's Avatar
try unboalting everything up to the exhaust. Than try lining it up? Thats what i did.
Old May 19, 2010 | 07:52 AM
  #2599
92 TOY's Avatar
oh dear God , i don't want to do that......that was enough of a PITA doing that.....i do know what you mean though.
Old May 19, 2010 | 07:57 AM
  #2600
shawns88's Avatar
that tube goes up to the exhaust manifold right? un bolt it from there and then try lining up then.
