92 TOY's 22re / crapped out / gotta start somewhere / thread
Old Apr 16, 2010 | 04:17 PM
  #2021
xxxtreme22r's Avatar
after you get that oil pan on you can come up here and change out my oil pan gasket for me. ENGNBLDR Rock gasket not doing well at all and I got only about 2000 miles on it.
Old Apr 16, 2010 | 04:41 PM
  #2022
92 TOY's Avatar
was it cork or otherwise....
break out the FIPG......
Old Apr 16, 2010 | 04:49 PM
  #2023
cork. grrrrr
Old Apr 17, 2010 | 03:01 AM
  #2024
92 TOY's Avatar
without me re-reading all the specs on the 1987 oil pan.....can you get away with an FIPG kinda fix?
that is a damm shame, considering what a pain in the Dartos Tunic (hehehehe) it is to access the pan.
Old Apr 17, 2010 | 03:25 AM
  #2025
I am gonna try the fipgish (rtv) fix, but I had already rtv'd it. maybe I wasn't supposed to in the first place or used the wrong color? I always forget which color rtv to use where. Fuel, water, oil etc etc.
Old Apr 17, 2010 | 03:46 AM
  #2026
92 TOY's Avatar
I'm thinking black is black.....I insisted on using the Toyota FIPG because I really don't want to do that part again......I'm gonna assume Black RTV is the equivalent to it though.
Old Apr 17, 2010 | 03:47 AM
  #2027
92 TOY's Avatar
87 calls for a gasket???
i see them advertised and I think i saw that in the Hayne's.....but, OY!
Old Apr 17, 2010 | 03:50 AM
  #2028
If I rememer right, mine had a gasket (was not cork) and that oem gasket was held in place by some beads that were run of either black or dark grey FIPG.
I might have had the oil pan bolts torqued down too much as well I don't know. The torque specs on those tiny bolts are real low though. And remember also I had to take this pan off from the beginning twice. That I am sure didn't help matters either.
Old Apr 17, 2010 | 04:01 AM
  #2029
92 TOY's Avatar
it's like 8 or 9ft/lbs.
took a pic of the page, not sure if it's readable...have the book right here...Chilton's 1970 to 1988 repair manual...
Old Apr 17, 2010 | 04:02 AM
  #2030
92 TOY's Avatar
sorry...no good
Old Apr 17, 2010 | 04:05 AM
  #2031
92 TOY's Avatar
try again...
Old Apr 17, 2010 | 05:55 AM
  #2032
yotarob2005's Avatar
I put my oil pan on with only silicone, used "the right stuff" from Napa. The stuff works great but is a little pricey!
Old Apr 17, 2010 | 06:01 AM
  #2033
92 TOY's Avatar
good point...i'm gonna go out on a limb and say you are probably as safe if not safer just using the sealer stuff.
Old Apr 17, 2010 | 07:00 AM
  #2034
Neither the FSM or my Chilton say to use a gasket, they give a procedure to fill the little grooves on the pan with FIPG. Napa does offer a gasket, but it looked cheap to me so I decided against it.
Old Apr 17, 2010 | 07:12 AM
  #2035
mightymouse's Avatar
I ended up going with the gasket and have yet to find a leak. That was last year and to be honest the gasket made life easier. I think it was a felpro.
Old Apr 17, 2010 | 07:17 AM
  #2036
92 TOY's Avatar
my imagination does not serve me well in trying to figure out how to place a gasket on that.... it's a 1-piece right?? so you have to get that pan clear of the strainer and all that just to fit a new one on....versus dropping the pan enough and giving due-diligence to cleaning it up and using the right amount of spooge on it.
Old Apr 17, 2010 | 07:19 AM
  #2037
92 TOY's Avatar
hey MIGHTYMOUSE....where the hell have you been?
Hi TOYOSPEARO...saw ya peekin'
Old Apr 17, 2010 | 07:23 AM
  #2038
92 TOY's Avatar
and to anybody else don't ever hesitate to post here...even if it's not relevant to current events
Old Apr 17, 2010 | 07:24 AM
  #2039
Yeah it was one piece but i had my pan off completely to clean it. When it came to installing the gasket it was a snap. i just placed it on the pan and snugged it up. It might be a pain in the butt if your's is hard to wiggle into place.
Old Apr 17, 2010 | 08:08 AM
  #2040
1990yota-pickup's Avatar
any high temp silcone should work...
i keep a calk tube in stock just for those type of occassions
