90 Sr5 Rebuild Paint Everything! PICS
Old Nov 27, 2008 | 10:27 AM
  #201
Tubbyfatty's Avatar
Cant go wrong with a case of mountain dew next to ya. haha.
Nice truck tho man, Im jealous.
Old Nov 27, 2008 | 10:45 AM
  #202
toyospearo's Avatar
Nice truck!!
great to see it running and happy!
Old Nov 29, 2008 | 10:04 PM
  #203
76ANTHONY's Avatar
shes lookin good yoter
Old Dec 1, 2008 | 11:57 AM
  #204
trbizwiz's Avatar
Did you make it home to Florida?? Congrats
Old Dec 1, 2008 | 01:45 PM
  #205
annoyingrob's Avatar
Signal lights will not work if the hazard light switch isn't plugged in FYI. All the signals run through that switch.
And just a hint for next time: I have that same engine stand, and had problems getting my transmission bolts to thread through it. So, I took a hacksaw, and cut down the mounts on the stand an inch. Works great now
Nice paint job too. I'm hoping to re-do my truck like that next year.
Old Dec 1, 2008 | 07:52 PM
  #206
YoterUp's Avatar
I MADE IT!!!!
Took me 2 days but i got here no real trouble about 600 miles in my alternator belt came loose and i had to stop and tighten it back up with a pry bar. Ill have to take a pic in front of a palm tree to prove im back. i would say the first 300miles i took it real easy 55mph-65mph after that it was 70-75 the the majority after that by the time i got to florida tho i was so excited i started following a lexas and stoped paying close attention and hit 95mph for a little while but ran awesome the whole way! IM PROUD!!!
Old Dec 5, 2009 | 02:44 PM
  #207
gTgarrett's Avatar
great looking truck!
I just rebuilt the 3.0 on my 4runner so I know how frustrating it can be!
try not to let it overheat and it will last you forever
Old Dec 5, 2009 | 04:34 PM
  #208
dakar652's Avatar
ugh...buy a bullet, it's cheaper...LoL. too bad you're in fl, i have a 350 that runs mint in MA. good luck...god speed
Old Jan 17, 2010 | 08:31 PM
  #209
YoterUp's Avatar
Big update!!!!!!!!!!
Alright i think i left off on my way home from michigan? Well ill do a quick catch up till we get to today.. i drove it home 80 mph 1246 miles and only had 1 small issue the altinator got a little loose when i got to georgia so the belt was slipping not a problem tho had some tools hoped out fixed it real quick then got it home to FL.... 3-4 months later a valve cover leak developed on both sides leaked like a SOB..clutch slave cylender went bad 2 times i think beacuse of the oil leak and oil and dirt and mudd getting all up in it.. starter went bad 6 months after the build and i am now replacing the clutch. motor still runs strong starts every day and i take this thing BOGGIN! lakes rivers mudd holes ect... the ol yota has had a rough 12 months since the build... thats a quick version to sum up the past 12 months... about a month ago i decided to do a SAS and go with 38s then about 2 weeks after i sent it back to the shop and i have a HUGE list of things that just got done to the ol yota... and it still wont be finished for another week so stay tuned ill post some info and pics i have at the moment tonight and ill add the rest throught the week! its going to be fun!!!
Old Jan 17, 2010 | 09:17 PM
  #210
YoterUp's Avatar
Ok im not exactly sure where to start from here i have alot already done and alot more comming this week so ill start from the beginning and go from there...
---I JUST GOT---
-SAS with 82 front axel
-Duel Rockwell M-37 case
-Rear full spool locker
-38/15-15 Boggers on new rims
-Got rid of the clutch fan and put a 2500 cfm electric fan
-Cold air intake
-Blue top marine battery
-2 kicker CVR 15s
-Crunch Mono block class D 1000watt amp
-Power acustic double den TV with navigation
-All kicker door speakers ( 2-4s, 4-5 1/4, and a PA Under the truck)
-All hooked to a 900 watt 4 channel Crunch amp
-A huge train horn set up
-I curently have 11 inches of life over stock (the pictures with tsls is only 8)
-4 wheel disc break conversion with fj 60 front rotors and V6 IFS calipers
-BRAND NEW stage 2 2100lb clutch centerforce
-Custom Raptor line bed liner 2 tone baint job black on black....
(do not have pictures up yet of all mods just 1st sas with 8 inches on TSLs all other pics will be posted later this week!)
*yota on 38 tsls with 8 inches before i just sent it to the shop
*NEW 38 BOGGERS AND RIMS**
Testing out the new SAS
THE SAS****
TRAC BARS***********
THE 15s IN THE BACK SEAT********
IFS
YOTA ON 33s NO LIFE BEFORE SAS***********
YOTA ON 31s AFTER MOTOR BUILD IN MICHIGAN THE BEGINNING!!!****
THE VERY BEGINNING WHEN I FIRST BOUGHT IT******
Old Jan 17, 2010 | 09:27 PM
  #211
dwnhiller93's Avatar
dude that thing is a beast.
Old Jan 17, 2010 | 09:28 PM
  #212
YoterUp's Avatar
thanks man!
Old Jan 18, 2010 | 06:08 AM
  #213
YoterUp's Avatar
They say i should be getting my truck back tonight if i get it ill post new pictures!
Old Jan 18, 2010 | 10:48 AM
  #214
Sweet! Don't forget to post them up if you get it back! I am excited to see the recent pics.
Old Jan 18, 2010 | 01:58 PM
  #215
Reedr125's Avatar
Nice job. I couldn't help but quiver when I seen that 16 dollar nightmare called the knock sensor wire! LMAO!
Old Jan 18, 2010 | 02:15 PM
  #216
YoterUp's Avatar
I wont forget i ended up not getting it today i had to get 1 inch wheel spacers so its taken me an extra day they also ended up having to custom make my drive shaft they are having trouble down sizing from a toyota u joint to a 2 1/2 ton rock well u joint.. lol
Old Jan 18, 2010 | 04:41 PM
  #217
vandert's Avatar
Hey, where you at in Florida?
Truck looks great, and on the SAS, you use a kit or build it yourself?
I'm doing engine swap first before I do the SAS, about to put my LC coils on the back of my 4Runner and my 2inch BJ spacers to tide me over till then then I'll go big like you
What gears did you end up with? 5:29"s or higher?
Old Jan 18, 2010 | 05:06 PM
  #218
tacho75's Avatar
Originally Posted by YoterUp
how am i sposed to tighten them back on then?
when you put the timing belt.........
Old Jan 18, 2010 | 05:43 PM
  #219
yoder519's Avatar
wow. that thing is a brute to say the least. great build up. or should i say... great BEAST up. awesoem truck
Old Jan 18, 2010 | 06:16 PM
  #220
YoterUp's Avatar
thanks guys its come a long way from beginning to so far in the last 1 1/2 years i live just north of orlando i live right near UCF... and to answer your question it was all built it was not a kit. i also just put 7 inch toyota leifs on it with a 3 inch drop down bracket in the front and a 1 inch shakle so i have 11 inches up front and 8 in the rear..
