90 Sr5 Rebuild Paint Everything! PICS
Old Nov 20, 2008 | 09:05 PM
  #161
stagger_lee's Avatar
everything looks good dude! Pretty darn clean job. So all have you have left is SAS and a bed bobb. lol cheers mate!
Old Nov 21, 2008 | 03:36 AM
  #162
Cyberman's Avatar
Did you connect the wiring to that one sensor in the back of the manifold, before putting the plenum on? It looks like you still have wires hanging out back there.
Old Nov 21, 2008 | 04:50 AM
  #163
YoterUp's Avatar
Yeah there is still some hanging wires back there its not done yet and i havnt actually set the intake on top yet i just put it up there to see which wires looked like they plugged into it im about to go work on it this morning ill fill ya in here soon!!
Old Nov 21, 2008 | 07:02 AM
  #164
trbizwiz's Avatar
Is she running yet?
Old Nov 21, 2008 | 03:29 PM
  #165
YoterUp's Avatar
Ubade I Can Taste It!
HELP ME!! Im so close i have a few things left an i mean that i dont know where this stuff goes and its the last part! HELP i just posted a new thread for quick help so i home i figure it out!
OK so
I circled all the problems and things im unsure about in white!! HELP
This is on the bottom of the power stearing pump i dont see them on all 3.0s do i need it or can i bypass them together? if i do need where does it plug into?
This is a mess and a pain in my A$$ but if you could send me good pics of your rigs or even explain how to plug this all in right, i have the hoses where i think they go i tried the manual no good picture!
Another pic of the same thing
And another
Where does that plug into? and is what i have right? any pics of your rigs would help!!!
THANKS FOR ALL YOUR HELP AHEAD OF TIME!!! ALSO THIS IS A 93 MOTOR GETTING INSTALLED IN A 90 TRUCK!
Old Nov 21, 2008 | 03:33 PM
  #166
YoterUp's Avatar
Need Help Fast Bump
Old Nov 21, 2008 | 04:11 PM
  #167
YoterUp's Avatar
No one is going to answer these question?
Old Nov 22, 2008 | 03:17 AM
  #168
chopitrakeit's Avatar
help request
hey, just saw your last post. snowing here too. Will check the 89 4 runner as soon as I get moving. Mike
Old Nov 22, 2008 | 12:02 PM
  #169
YoterUp's Avatar
She Runs Kinda!
Well i got it going this morning had a few little mishaps but t-got them taken care of i started out with a antifreeze leake but it was nothing major just the plastic cover over the thermostat forgot to tighten the bolts down, then i was 180 out on the destributer got that fixed
NOW it wont idle right, i sits at about 200rpms and barely moving and then adjusting the timeing doesnt help much, every once and a while it will idle up REAL high and i have to shut the truck off anyone herd of that? any ways i bled the breaks and the clutch so now all i have left is to figure this idle problem out and the timeing if you know anything or have any idea let me know thanks!!
Small sign of life!
Went to the junk yard to find me some parts! this is what i found. just like it sits! Someone took it all apart and didnt even take anything. nothing was missing!
Old Nov 22, 2008 | 01:46 PM
  #170
YoterUp's Avatar
Ok new update!!! QUESTIONSS
Ok scratch the last post that was an axident on my part!!!!
Ok so it idles at about 500 now when stumbles a bit then dies. if i turn the cap sometime is idles a little better sometimes a little worse but all in all it dies. i havnt adjusted the throttle screw yet and i havent completely set the destributer? Anyone have any ideas?
So far im thinking mabe i crossed a vaccume hose?
Would this happen if i was a tooth off on the timeing belt?
What do you think i need to be looking at to fix this?
Other then just that problem shes running i bled the clutch and brakes fresh power stearing fluid break flid antifreeze and oil! shes ready to run after i fugure out this idle thing... Also i held the throttle 3/4 open and soon as i turned it on it would studder a bit then would rev right up but then if i let off it would go back to 500rpms and die? Need a little more help guys come on im almost there!! youve got me this far!!! Thanks alot yall!!
Old Nov 22, 2008 | 03:06 PM
  #171
Cyberman's Avatar
Verify your all of your timing (ignition and cams), check your wires, check your hoses. If you can give it a little gas, and can maintain speed, give the idle screw a tweak.
Old Nov 22, 2008 | 04:18 PM
  #172
YoterUp's Avatar
Wink
well i did a little checking and got her to run better lol i didnt notice i had one of my plug wires disconnected! but i got it now! lol, after that i realized i was just trying to move to fast so i took me a step back and found one or 2 other little things. i pulled one of my vaccume lines and plugged it and it ran alot better but still idles low so im going to mess with the idle screw in the morning and do a little vaccume plugging! i also think the bad gas idea is a factor i thought about it and this truck has been sitting for almost 3 months and before that this motor had sat for 3 years and i never cleaned out the fuel lines or anything so im going to get some premium and octane buster tomorrow and see if that helps theirs less then a 1/4 tank so i can get away without having to drain the tank! i also had some NASTY white stuff in my clutch mater cylinder when i bled it it was not pretty.. but i got it all out and the clutch and breaks work very well!! its all looking good and THANKS CYBERMAN!!! i appreciate the call today it helped me find out im an idiot and had the hose clamp in the way of the throttle so it was stuck open 3/4 of the way!! you know me always doing something stupid!! anyways should have her running in the morning and ill let you all know how it goes WANT TO SAY THANK YOU again for all the help on here especially anthony and cyberman!!
If your ever in florida you'll have to give me a call i owe yall a beer!
  #173
YoterUp's Avatar
how do you check your cams? i dont get that by the way!
Old Nov 22, 2008 | 04:39 PM
  #174
76ANTHONY's Avatar
lol, finallyyyyyyyyyyyyy, sheeesh. oh and i had to let my runner run for about 20 minutes before it would idle , then it was fine, dont know what it was, wish i could help ya. i know theres a relearn for the ecm.
Old Nov 22, 2008 | 05:34 PM
  #175
Cyberman's Avatar
Cam timing, i.e. the timing belt, crank at tdc, and cams aligned.
Just let me know where in FL. I was just in Orlando last month.
Old Nov 22, 2008 | 06:36 PM
  #176
YoterUp's Avatar
im just north or Orlando! im about 10 min out from UCF area id say im 25 min north of down town. any time man i know a BUNCH of great wheeling places im sure they are a little different then what your used to florida is unique! its alot of MUD but some of its alot of fun. lol i think i have the longest build on here! just for the motor! haha. Im good like that
Ill see what i can do about getting some clean pics of this thing once i degrease the motor and wash it i bet this thing will look good out in the sun! im looking forward to seeing her all cleaned up it might have to wait till i get back to florida tho its freezing temp here id spray water on it and it would freeze before it ran off! lol Thanks alot yall
Old Nov 22, 2008 | 06:38 PM
  #177
YoterUp's Avatar
Do you think the Computer is different because of the 90 to a 93? i dunno just thinking of reasons why, its run for a total of about 25 min today not consecutively but total. id say the longest i got it to run was 10 min
Old Nov 23, 2008 | 12:05 PM
  #178
Cyberman's Avatar
The computer shouldn't matter. As long as you used most of the sensors from the old engine, it's not going to be that big of a deal.
Keep pluggin away.
Old Nov 23, 2008 | 02:56 PM
  #179
YoterUp's Avatar
Help Update
Ok NEW PROBLEMS!!
Got it running better, started today off moving to a heated garage with a concrete floor! The truck backed up on the trailer and then drove off into the garage, then we realized we had a fuel leak found it under the top of the intake and fixed that then we had a vaccume line problem so we switched a wire or two and then capped off one or to, then we fixed the manifold leak i had, Then we took a timing gun to it and got timing set to where its supposed to be 10 degrees off top dead center, it idles right now at about 800rpms and starts right up PROBLEM IS
1. it doesn't build pressure in the radiator we took it for a quick up the street and back before we got to the end of the road the check engine light came on then we turned around and got back we realized that the top of the radiator was BURNING and the bottom was ice cold, so i went and got a new thermostat its a 180degree one now i let the thing run for 20min in the garage and it built up to half temp no engine light came on but it still didn't build hardly any pressure in the top hose. the heater in the truck works also. then i tried to drive it home which is only 2 miles down the road got 1/2 way there and engine light came on again. so when i got home i put it back in the garage and let it run for about another 20 min no engine light nothing no leaks ran fine, took it for a drive got about a mile down the road engine light again. I don't get it. and i don't know for sure i really didn't test the theory but it seems that the engine light likes to come on around 50mph. im not sure if that has anything to do with it or not.
Also timing seems dead on but it still sounds like i have a little miss it idles fine but if your listen real close you can here the tone change from time to time just for one hit tho. its kinda hard to explain
oh cant forget i shorted out my diagnostic box you know how you check your code from your check engine light and it flashes like its throwing a code but i don't know how to read what its saying, and that is with no check engine light on i dont know what that means exactly. if you can think of any ideas from this let me know ill post some more pics tomorrow
Old Nov 23, 2008 | 03:08 PM
  #180
thedude42's Avatar
at least its runnin man just a few more tweaks!
