89 4Rnr IFS wandering steering, running out of parts to replace!
Old Oct 30, 2013 | 07:11 AM
Gevo's Avatar
You know, I don't see the adjustment screw altering freeplay in the gearbox, it does definitely change the force required to steer.... I had some freeplay in mine, it was 95% in part due to the connection from the union joint to the steering column... the bolts were loose at the rubber bushing... check that too!
Old Oct 30, 2013 | 07:20 AM
MudHippy's Avatar
Well, you can beg to differ with the FSM all you want. But it's a losing battle, virtually every time.
And whether or not you want to believe what I say, makes no difference to me. I couldn't care less. I'll reiterate this though, I've done it, and it does.
Old Oct 30, 2013 | 07:35 AM
derockus's Avatar
Hey, there's a good lead... Where do I find that joint? Is it under that black boot?
Old Oct 30, 2013 | 07:40 AM
scope103's Avatar
Perhaps what Gevo saw was just that his gearbox was already sufficiently tightened, so that add'l tightening (over-tightening) only increased the steering effort. In his case his problem was elsewhere.
We often need to widen our gaze.
And I'm w/MudHippy on his basic point; the folks writing the FSM knew what they were doing. Always start (and usually end) there.
Old Oct 30, 2013 | 07:47 AM
  #25
Gevo's Avatar
Was just thinking out loud Mudhippy, don't take offense. One thing I like about the forum is.. you can think out loud and other people chime in and you figure ˟˟˟˟ out that way
derockus, my joint is under the boot.
Old Oct 30, 2013 | 07:51 AM
  #26
Gevo's Avatar
Scope, I am an advocate of following the fsm... however, sometimes unless a part is brand new it doesn't act like it should and the fsm doesn't really give many suggestions on how to make it work, it says 'replace'.. With that said, I have now over a 100 pages printed from the fsm and it's been a gold mine for me while putting my engine back together... it does take some experience to use it efficiently though, as i've been learning.
AustinTaco
Aug 22, 2022 10:45 AM
voiddweller
19
May 2, 2016 09:10 PM
Ott47
Jun 26, 2015 05:21 PM
Bamripzit
Jun 20, 2015 04:53 AM
Corey
Jun 14, 2002 08:41 AM
