89 4Rnr IFS wandering steering, running out of parts to replace!
You know, I don't see the adjustment screw altering freeplay in the gearbox, it does definitely change the force required to steer.... I had some freeplay in mine, it was 95% in part due to the connection from the union joint to the steering column... the bolts were loose at the rubber bushing... check that too!
Well, you can beg to differ with the FSM all you want. But it's a losing battle, virtually every time.
And whether or not you want to believe what I say, makes no difference to me. I couldn't care less. I'll reiterate this though, I've done it, and it does.
We often need to widen our gaze.
And I'm w/MudHippy on his basic point; the folks writing the FSM knew what they were doing. Always start (and usually end) there.
#25
derockus, my joint is under the boot.
#26
Perhaps what Gevo saw was just that his gearbox was already sufficiently tightened, so that add'l tightening (over-tightening) only increased the steering effort. In his case his problem was elsewhere.
voiddweller
19
May 2, 2016 09:10 PM
Corey
Jun 14, 2002 08:41 AM
