87 4Runner 22RTE Won’t Start All of a Sudden
#42
Got it - thanks! I assume I can justkeepo the existing spade connector on the starter and cut/connect the upper engine bay end to the relay right? That way I can leave the OEM connector on the starter and don't have to mess with getting in to the actual starter area down below.
#43
You don't have to cut no factory wires or connectors, the only thing you're gonna do is, add one male spade connector and one female connector to the relay, then you'll disconnect the stater solenoid female connector and go from there.
#46
Fat black wire female connector goes to stater solenoid male connector.
Skinny black wire male connector goes to female connector you disconnected from stater solenoid.
Red fused wire + battery to relay.
White wire ground.
White wire ground.
#47
Stay tuned.
#48
Charles4x4's,
Cancel your order for ignition switch. The fact that the C.O.R. clicks when you crank means IG switch is good.
Absence of starter relay on automatics, and wrong wiring of starter relay from the factory are proven faults. Fix them, because no matter what else you do, the fault will still be there. The reason problem is intermittent is because smooth starter solenoid operation, strong battery, un-corroded / un-pitted IG switch and starter relay contacts mask the problem.
That black module with black, pink and white wire looks strange. Could be unique to the auto.
Correct, Charles4x4, you do not have a starter relay like the manuals have.
One RAD Showed:
This is how to rewire a truck with a starter relay that was wired wrong IN THE FACTORY. Costs $11 and 30 minutes to fix. Easier than Hotshot (ask Griswald).
Exactly.
Make kit exactly as shown.
Use at least 12AWG wire.
Connect exactly where i say to connect the pins....
VROOOM!
One RAD Showed:
Sorry if I'm making this harder than it should be. I think I am going to simply replicate this
VROOOM!
#49
#50
Yes, $65 is expensive. try Amazon Relay. Find the "Bosch" one now Tyco in Germany or somewhere other than the communist bully of Asia.
You only need a few feet of wire, but yeah, nice to color-code.
Here's JPL's as built and installed:
https://www.yotatech.com/forums/f120...l#post52370752
#53
Solved! Thanks guys. This has been a multiple week, multiple $100 plaguing problem. Worked like a charm!
Attaching a pic of the final product along with one of the ‘87 which I haven’t shown yet on the forum. Only one project left till the partial restoration is complete - checking out the fuel sender as gauge only works in middle 50% of fuel level. Dropping the tank tonight!
#55
ofmits cycle. But who knows - only way will be to drop it and find out.
#58
There is info about it somewhere, the solution to the problem is to replace the fuel sender inside the fuel tank, for me it's a $163.00 replacement part i'll do it sometime down the road. https://www.amazon.com/dp/B00KTJD8YM...=1I6ZV62SLM35J
#59
Yeah, that kind of sucks, but you have a unicorn and that comes with some extra problems that are hard to fix, maybe an experienced electrician could rebuilt the copper part that breaks on the fuel sender but who knows.
#60
Maybe you can do something about it, and since you want to drop the fuel tank do some cleaning on the fuel sending unit. If it works that's great, if it doesn't at least you tried and there is nothing to loose it's a learning process. https://www.yotatech.com/forums/f114...repair-252091/
