4RUNNER no start but cranks new spark plugs and strong odor of gas
Old Aug 20, 2019 | 11:25 AM
Aramos333's Avatar
So it does not start but cranks I just replaced the spark plugs and no go I also tried starting it with quick start but no go either so I went to the next step if all spark plug has power and yes so I crank it and a strong odor of gas coming from the engine also it may leak Thro the exhaust anyone help ??
Old Aug 20, 2019 | 12:54 PM
5 Fists's Avatar
Welcome to Yotatech.
Which engine are you working on?
Do you see any fuel leaking out anywhere in the engine bay?
Old Aug 20, 2019 | 01:49 PM
scope103's Avatar
Originally Posted by Aramos333
So it does not start but cranks I just replaced the spark plugs and no go ...
If all you did was replace the spark plugs, what COULD be wrong?
First, check that you haven't mixed up the firing order. (If you don't remember the firing order, we'll have to know make/model/engine/.... to help you.)
Next, check that the plugs are firing. Put the inductive lead of your timing light on each plug wire. If the light flashes, you've got spark.
Is the spark at the right time? Since you've got your timing light out, check the timing (hard to be exact with no start, but you only need to get it close).
Old Aug 20, 2019 | 01:50 PM
Aramos333's Avatar
Yes it was leaking thro the exhaust pipe down below the car
Old Aug 20, 2019 | 01:54 PM
Aramos333's Avatar
And I searched the firing order and re orderd the wires to the corresponding spark plug and still no go it was wanting to start when I changed the spark plugs so when I saw the old ones they were black so I guess I was running rich but when I was off-road it just stalled on me but before that the whole day it was fine no issues at all
Old Aug 20, 2019 | 01:57 PM
Aramos333's Avatar
Im working on a v6 3.0 that’s all I know
Old Aug 20, 2019 | 02:24 PM
5 Fists's Avatar
So it was starting before you put new plugs in?
Old Aug 20, 2019 | 02:25 PM
Aramos333's Avatar
It started but then I’d put it on drive and died but I’d put it on reverse and it go slow so then when it died it wouldn’t start back up this is before the new spark plugs
Old Aug 20, 2019 | 02:26 PM
Aramos333's Avatar
It wouldn’t start but it would crank
Old Aug 20, 2019 | 05:59 PM
Aramos333's Avatar
Soo I might be thinking that my fuel filter is clogged cause the intake thing is dry af so I’m gessing it’s the fuel filter
FinallyOffRoad
Feb 17, 2016 03:06 PM
YoterPower
Aug 19, 2012 02:48 PM
shafner30
Feb 6, 2012 01:34 PM
ltgvolsrock1
Aug 5, 2009 03:53 PM
cccp
Jan 10, 2006 03:55 AM
