4Runner Canopy Questions
Old Sep 10, 2016 | 11:30 PM
stanz's Avatar
Getting ready to remove my canopy to do some prep for a vinyl wrap job on my 86 4Runner. I've never had the canopy off and have always been nervous about leaks for when I go to put it back on.
My questions are as follows:
-Should my original gaskets turn out to be in bad shape and not reusable, what do others us as a replacement since all the gaskets are now obsolete from the dealer?
-I just got a Softopper (still in the box). Do the gaskets from the soft top frame work on the factory hard top?
Thanks!
Old Sep 11, 2016 | 04:37 PM
RAD4Runner's Avatar
Thanks!
Hi Stanz,
If the cap had never been taken off nor abused, most likely the gasket will still be in good shape. It's a robust piece of rubber. Just be careful when taking it off so you don't tear it up. Before I put mine back on, I cleaned and rejuvenated it with 100% silicone dielectric grease (Permatex).
Straightforward to remove and replace the cap. Just don't forget to label the cover-off switch and its location here.
Old Sep 11, 2016 | 05:58 PM
Nervo19's Avatar
From RadRunners link so I can save it to my computer. Photobucket would not let me:
Old Sep 12, 2016 | 02:42 PM
flagbasher's Avatar
I've heard that the top has a re-install sequence in the manual that, if you follow it correctly, will NOT result in the top leaking afterward. Basically the jist is that people aren't following the sequence, it isn't seated properly, and then it leaks.
I've had the Softopper for a while. I don't even remove it in the winter. I'm just careful not to flex the windows under 40 degree weather.
128keaton
Feb 23, 2022 09:51 PM
artemyk
Jan 14, 2021 10:27 AM
philip64
Apr 20, 2017 04:47 PM
doc702
Jul 28, 2016 06:06 PM
dbbowen
Jul 1, 2016 06:31 PM
