4runner belt squealing crank pulley busted ???
alright so my alternator snapped the other day i bought a new one and now they just squeal and burn rubber and next to the bottom crank pulley is the alternator pulley and it moves freely i can move it side to side like towards the crank pulley and away from the crank pulley toward the block is that normal ?
Sure it's not the PS pulley? http://personal.utulsa.edu/~nathan-b...67timingbe.pdf That's "next" to the crank pulley, and held to the crank pulley with 4 8mm bolts. If those bolts came loose that pulley will wobble and do you no good at all.
If the "alternator" pulley is wobbling, your crank pulley is loose, and you've got real problems. If that crank pulley has been wobbling for more than a few minutes, it will chew up the end of the crank, and you may not be able to re-install it.
Good luck, and let us know what you find.
The water pump is very hard to turn its -20 outside right now and the power steering was having issues to it would just burn the belt up but the crank pulley is still solid and the bolts are their. Is the crank pulley supposed to separate from the alternator pulley as pictured ?
You need to take it off and see what all is broken, looks like the pulley slipped off the balancer at least. Also, with the belts off does the fan pulley spin by hand now?
Yes they line up fine the outer pulley is solid but the inner pulley is loose and i can spin it and the fan pulley does not spin
also the fan itself will still spin by hand
I can see it now. The alternator and A/C pulleys are one piece, but have an annular rubber ring that separates them from the "center" of the pulley attached to the crank. (the rubber provides the damping for the harmonic damper). You've torn that rubber apart, so the entire balancer is now non-repairable.
That part has a dealer price of about $300 13408-65011, so I would consider a salvage part. If you're thinking of a pick-and-pull yard, remember that the spec torque on the crank bolt is 181 ftlbs. More importantly, even if you bring your favorite gorilla along to supply that torque, you're going to need a tool to keep the crank from turning while you do it.
You may have failed the rubber just by freezing the alternator, but I would have expected the belt to disintegrate first. As bswarm advises, you need to spin-test the fan bracket (and probably the A/C idler and PS pump) to see if they were damaged too.
