3VZE TOP END+homemade ??Y PIPE?? MOD!!!
Old May 17, 2007 | 09:59 PM
  #61
Guardian_Saint's Avatar
What kind of pipe did you use? Did you got it from auto parts or muffler shop? Also what kind of angle do I need to do this mod? Thanks.
Old May 20, 2007 | 06:27 PM
  #62
Chief_Yota's Avatar
heres my twin termin,badass gear right there. i know its ironic ,but thats not the cheapest way to end your exaust line,since i did not buy headers,and i dont have to buy any cat i putted extra doe on something else.anyway i only paid 115 bux for the 2 of hem. long story..(and i still dont know if im putting the two of hem on, maybe its just useless..)
Old May 20, 2007 | 06:33 PM
  #63
Chief_Yota's Avatar
Old May 20, 2007 | 06:35 PM
  #64
Chief_Yota's Avatar
Old May 20, 2007 | 06:37 PM
  #65
Chief_Yota's Avatar
this is the original setup with the closed ending using the manifold end .for that i just used some peices of metal ,2 actualy ,one over the other ,and i cutted them in a circle patern,so it could fit in there ,than i placed the manifold seal on it and to finish i bolted the crossover pipe end on top of that and i sealed it with some muffler compound ,but the compound is really not doing anything i just putted some cause i had it close to me.
Old May 20, 2007 | 06:40 PM
  #66
Chief_Yota's Avatar
this is the new pipe ,its not yet finished ,so ill be comming up with mesurments next time. but for now its fits perfectly .and it does not come close to any wires ,or the releasse cylinder,but i wont take any chances ,im gonna use some heat proof tape on thoses. as for the pipe its gonna be all welded (dont worry)
Old May 20, 2007 | 06:43 PM
  #67
Chief_Yota's Avatar
and it fits right in there
as for the images sorry for the size ,ill be updating them soon.
Old May 21, 2007 | 07:01 PM
  #68
Chief_Yota's Avatar
im making a list of all the stuff i had to buy to get this done.
Old May 21, 2007 | 07:13 PM
  #69
Thanks man, I'm looking into this mod myself, I am in the process of diong the HG and transmission swap and will do this mod, but have to wait until you are done. I would like if you list what angle did you use on those pipe so it'll be easy way to go and purchase them easier. Why two muffler? It doesn't seem like you are following as the picture you post, will this mod mate before the O? Sensor be located? Thanks a lot. GL man.
Old May 21, 2007 | 08:22 PM
  #70
CoedNaked's Avatar
If you are going to weld it, you should have bought mandrel bends instead of pressure bends for your exhaust pipes. That will reduce heat and help flow & performance.
Old May 21, 2007 | 08:33 PM
  #71
Chief_Yota's Avatar
thats a good fact right there,but i guess the awser to that is im kinda out of time so im doing with wut i got here,my girlfriend is gonna kill me if i take one more weekend on my damn truck.this weekend is the last,well for this mod
Old Jun 4, 2007 | 05:48 PM
  #72
Chief_Yota's Avatar
alright ,so i had a major problem with my injectors,numb 1 was blocked numb 6 was blocked ,so i decided to clean them myself,so i took off the screens and soak them with injector cleaner ,i connected them to a 12v output and sprayed air by the tip.
Old Jun 4, 2007 | 05:56 PM
  #73
Chief_Yota's Avatar
i had to change one cause it had major leakdown,now i understand why i had so bad MPG anyway thats my setup to clean them,be really carefull not to set fire to your garage thoe.!!
Old Jun 4, 2007 | 06:15 PM
  #74
dijlop's Avatar
good call. looks great. cheif pipe mod. i like it. im gonna have to come up with something random to do to my 22re that i can name. yep. real quick, what type of paint did u use? and what type of prep did u use b4 painting it?
Old Jun 4, 2007 | 06:30 PM
  #75
Chief_Yota's Avatar
as for the problem with the distributor not getting to sit in position ,i found the problem. plz no comments: i putted my heads THE WRONG SIDE. ahhh
,when i first see that,i was really pissed then i just figured out,its all good , there exacly the same ,exept the mount for the power stering and the distributor hole,so i putted shims behind the P-ST bracket and retaped the dist hole and voila.! anyway ,for the cheif mod heres the update: i got the pipe welded and im cutting the last peice that conect everything up.
Old Jun 4, 2007 | 06:34 PM
  #76
Chief_Yota's Avatar
and heres the view of tranny clearance,not much ..he:
Old Jun 4, 2007 | 06:36 PM
  #77
Chief_Yota's Avatar
Old Jun 4, 2007 | 06:39 PM
  #78
Chief_Yota's Avatar
ok i know the welds look like ☺☺☺☺ but im not a big fanatic of welding.
Old Jun 4, 2007 | 06:59 PM
  #79
mudbutt's Avatar
Just so you know your cam caps will not line up correctly on the heads, they are/need to be line bored. If you want your engine(topend) to last you better remove the heads and switch them to the correct side. You now have mismatched caps right to left.
Old Jun 4, 2007 | 07:07 PM
  #80
Chief_Yota's Avatar
i know it sounds crazy but the cam caps fits perfecly,no mismatch watsever,and i sealed them anyway with some high heat and oil ressitant packing. and i cant afford to switch the heads ,its gonna cost me another set of head gasket and alot of pain in the butt. so there is no turning back now.
