3VZE cam plugs additional sealant????
Old Aug 1, 2010 | 05:39 AM
Andy A's Avatar
3VZE cam plugs sealant or no sealant??????? I was reading the FSM at http://personal.utulsa.edu/~nathan-b...68cylinder.pdf and it mentions no sealant, putting them in dry. I notice the plugs have a kind of rubberized coating. The only thing it mentions sealant on are the #1 & #5 bearing caps.
Old Aug 1, 2010 | 10:35 AM
bugs1961's Avatar
I've put them in dry in a couple of 3.0s and haven't had any leaks after a couple of years. I think the rubber coating seals them up pretty well. I did install them in conjunction with the rear cam caps and everything was very clean. If I was putting them in with the bearing cap already installed, I'd coat the rubber outside with multipurpose grease to help with pushing them in.
Old Aug 1, 2010 | 10:57 AM
vital22re's Avatar
totally a bro
if its a concern and you dont' want to risk doing the job twice, then put a light coat on the plugs and in the corners before you install the valve cover.
clok
Aug 1, 2015 09:42 PM
thefishguy77
Jul 30, 2015 10:59 AM
91yotapup
Jul 27, 2015 07:19 AM
yourrealdad
Jul 21, 2015 11:13 AM
smiley52
Jul 11, 2015 05:16 AM
